FRPP adj clutch cable busted. where to get OEM?
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
i used to break clutch cables all the time. i had a worn out stocker that actually snapped the steel cable. i kept buying cheapy parts store crap. they would break where the plactic part is that sits on the bellhousing, where the little c lip holds the cable to the bell housing that plastic crap would break into pieces and ruin the cable.
i bought a FRPP adjustable cable and it has worked great for over a year and today it broke right where it did before, the plastic part at the bellhousing, where the little c-clip thing holds on to the cable it pulled apart there.
i thought these adjustable cables were pretty nice, it worked for a while but i guess they are crap like everyone says
now i am needing an OEM quality cable. i have a FWA also i will just use that setup.
where can i purchase an OEM cable, or would ford carry them?
Buyfordracing has them for about 50 bucks shipped as well.
Kinda strange that the cables keep breaking at the same spot, huh.
Good luck.
I've gone through 3 of the Ford cables in the past 3 years, the $50 ones from the heavy duty clutch upgrade kits. Two frayed by the quadrant and one had the cable collapse by the firewall. Might have something to do with the UPR quadrant, but I've had that for a good 7 or 8 years.
I just replaced the last one with the Maximum Motorsports cable this week, along with their quadrant and what a difference! The cable is so smooth it feels like a hydraulic foreign car clutch! Now I'll have to see how long it lasts. I used to get about 4 years out of the old Ford cables.
thats the problem i have had with cables in the past. the actual cables are fine. just the insulation and plastic parts break due to heat and whatnot.
anyone got any ideas on something to wrap the new cable up with to help with heat problems?
its been so long since i have messed with an oem style cable, i am assuming i am going to have to use the 2nd hook on my 2-hook quadrant (one closest to firewall) and then take up the slack with the FWA?
Yes, it worked fine with my UPR firewall adjuster, but the part that fit in the adjuster is a bit smaller than the opening in the adjuster. Also, the metal band for the mounting strap is a bit further down the cable. I was not able to mount the strap in the stock location and still haven't mounted it permanently. Any of you guys have a solution?
