thehueypilot
jbuening said:One thing that has happened to me in the past has been air trapped under the temp sending unit, creating steam and giving false temperature readings. Since you are posting actual temp readings, i assume you have a good aftermarket temperature gauge and not relying on the stock electronic unit. Is your aftermarket gauge electronic or mechanical? Loosen your sending unit unit coolant starts to leak out and then retighten. See if that helps. I've also heard of people drilling a 1/8" hole at the top of the thermostat to prevent air from being trapped behind the thermostat.
I good thermostat will already have this vent.....the question is; was it installed with the vent located at the top?
