Fuel Filter Hairpin Clips
  • Thread starter Thread starter 95GTV8
  • Start date Start date Mar 5, 2006
95GTV8
386
Washington State
Mar 5, 2006
  • Mar 5, 2006
I went out to change my fuel filter yesterday, because my car takes a little longer to crank before she turns on then normal. I found the filter and the two fuel lines that go out from it have these annoying clips on them. When you push the ends apart are you supposed to remove the whole plastic housing? Or just move the clip down a little bit and then pull the fuel line off? I was also reading how i need some fuel pressure relief guage to put in a valve? I had the front end of the car lifted up farther than the rear, i know fuel will come out of the lines but how much? And do i need to buy this silly thing to relieve the pressure? All im changing is the fuel filter. Thanks.
C
criticman
723
Rome, GA
Mar 5, 2006
  • Mar 5, 2006
On a fox body, you undo fuel connector in trunk/hatch. Crank the car a few times until it dies (fuel pressure/fuel gone). Then you can deal with the filter.
When I bought a replacement filter from the parts store, it came with new clips. I released them per the Haynes' manual.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Mar 5, 2006
  • Mar 5, 2006
When removing the lines from the filter you just push the white clips down a bit and then you can pull off the line. To relieve the pressure from the system, I just stuck a screwdriver in the schrader valve near the passenger side valve cover. I covered the valve with a rag to keep fuel from spraying everywhere.
HISSIN50
34
129
Mar 5, 2006
  • Mar 5, 2006
Make sure your new filter has new hairclips since you will probably break one or both (they get brittle). I grab them with needle nose pliers (if I have new clips) and pull on the end of the clip while pushing the tabs in with my fingers. Wear eye protection while removing the filter lines.
You can use a FP tester kit to safely and cleanly open the schrader valve on the fuel rail and drain most of the fuel in the line (though not really safe, people have put a rag over the schrader valve and pushed the core in and let the rag catch the fuel. Be sure the motor is COLD).
Good luck.
snoboardcore
276
New Hampshire
Mar 5, 2006
  • Mar 5, 2006
if u want to releive the pressure in the fuel lines just pull the fuel pump fuse start the car and let it run out of gas. Do the fuel filter swap then put the fuse back in and start the car.
HISSIN50
34
129
Mar 5, 2006
  • Mar 5, 2006
Where is the fuel pump fuse?
95GTV8
386
Washington State
Mar 5, 2006
  • Mar 5, 2006
yes, where is the fuel pump fuse? and where is the schrader valve? I will grab some new hairplin clips, but i was bout to just break the clips off when my dad told me about relieving the fuel pressure. I figured it'd be best to wait and ask how to relieve the fuel pressure on stangnet.
sgarlic
3,085
Mar 5, 2006
  • Mar 5, 2006
I never bothered releasing the fuel pressure, although it's not something I am recommending or anything.
I just take a small flathead screwdriver and pry those little white clips out.. every filter I bought for the 88 had new white clips with it. I leave the filter where it's at (with that band clamp tight) so that I can pull the lines off without having to have my other hand up there. I just take the output line off first, let the gas drain in to a bucket, then pull the input line off, then remove the band clamp, slide it out, etc.
95GTV8
386
Washington State
Mar 5, 2006
  • Mar 5, 2006
allright, i will try again just need to get some new hairpin clips, and i will look by the passenger side valve-cover for that shcrader valve as raceoholic said. I have a q bout the shcrader valve. Once i relieve the fuel pressure how long does it take to build it back up? just turn the key into the on slot and let the fuel pump fill the lines up again?
sgarlic
3,085
Mar 5, 2006
#10
  • Mar 5, 2006
  • #10
Once you turn the ignition on it will build back up.. I've heard of people needing to cycle a few times, but I never bothered.. just turn ignition on, wait til pump stops priming, then crank til it starts.
C
criticman
723
Rome, GA
Mar 5, 2006
#11
  • Mar 5, 2006
  • #11
I just re-posted the tech section of my site (did a redesign) and realized I have a short write up on fuel filter replacements here: http://criticman.com/tech/fuelfilter.php
95GTV8
386
Washington State
Mar 5, 2006
#12
  • Mar 5, 2006
  • #12
awesome, i will check it out! Thanks everybody for the help.
Does anyone know where to buy this
  • PvolkStang
  • Jul 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2025
manicmechanic007
Zero fuel pressure @ Shrader, but over 100 PSI at filter
  • Stang337
  • Jul 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 10, 2025
JD1964
D
Fuel 1985 GT Fuel Line Diagram
  • DienstXIV
  • Apr 17, 2025
2K
Fox 5.0 Mustang Tech Jul 12, 2025
DienstXIV
D
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
