- Jan 12, 2007
- 169
- 1
- 18
I've got a 351 Cleveland, I converted to EFI last summer, but I've got one annoying problem!
From a dead stop, if I accelerate rapidly, it pops back through the intake.
If I get back in the throttle too quick, it pops back through the intake.
If I go WOT, it surges and pops back through the intake.
In park or neutral, I canquickly blip the throttle and it hesitates then revs.
If I smoothly accelerate, it does fine.
WTF is wrong.
I've pulled the codes and got all the stuff I don't have.
EGR, EVR, CANP, AIR, all the stuff I don't have.
I don't have rich or lean codes, but everything I've read points to "lean pop".
I have a new C&L 76MM mass air, yes it popped with the old one.
Adjustable FPR, I've tried to adjust it to give more fuel, still pops.
24lb/hr injectors, with 24lb sample tube.
New ign module, stator, etc. (recent engine rebuild, got new stuff)
Timing set at 8*, I've tried more and it still does it.
TPS set at .95, I've tried to move it both ways with no change in the popping.
70MM throttle body, did it with the old one too.
New intake gaskets, and such, still pops.
MOROSO Ultra 40 plug wires, popped with the FMS wires too (engine rebuild)
New ACT, ECT, O2 sensors, TP sensors. (all new sensors with conversion)
With the 19lbers, it would pop in park or neutral when I blip the throttle once or twice.
It seemed to pop more with the old 19lbers than the 24lbers, so I'm guessing it could it be a lean pop.
Any thoughts, do I need bigger injectors?
I've done the manifold a couple times what with the rebuild and a rear seal leak, both times I used new gaskets and it didn't change it.
I've got 2 bbl Cleveland heads with 2.07 intake 1.65 exhaust valves, ported and polished, factory 2 bbl intake with injector bungs welded in, custom-homemade billet adapter to adapt a '00 econoline upper TB plentum to the 2 bbl intake.
Here it is if it helps: http://www.cardomain.com/ride/2425255
I can't datalog, I wish I could, but I only get the codes for the extras I don't have.
Is it leanin' and causing preignition?
Any help would be greatly appreciated, Chris.
WTF is wrong.
