Fuel Pressure Adjusting
AIbandit
76
Hi I have an 89 5.0 I was wondering what my fuel pressure should be at idle and various rpms.
I have afr heads, rpm II intake, ecam ,24lbs injectors 75mm maf, and tb. Shorty headers.
Thank you for your help
May of been sent from my G2, Expect errors.
It's generally acceptable to have the fuel pressure set between 38-42psi with the vacuum line "off". It should read approximately the same at all RPM. If you're stabbing the pedal hard and it's dipping far below the recommended levels and is unable to, or having trouble recovering, you may have a weak, or undersized fuel pump.
The stock fuel pump is only rated at 88lph and will often become inadequate when big horsepower mods are performed.
