Fuel pressure problem
  • Thread starter Thread starter bock
  • Start date Start date Apr 18, 2005
bock
648
Montreal,Qc
Apr 18, 2005
  • Apr 18, 2005
I cant get more than 40psi.
The fuel regulator is new(Kirban adjustable).
I tried 2 different gauges.
I can go under 40,but when i get to 40 , im turning the bolt of the regulator but the pressure stay at 40.
Can it be my fuel pump?
Its a holley 190 lph.And all was working great for 2 years.
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 18, 2005
  • Apr 18, 2005
I would say it could be the fuel pump, or a kinked fuel line, or a fuel leak somewhere.
Sicarius428
2,085
Apr 18, 2005
  • Apr 18, 2005
How old is your fuel filter? Might want to change that just as an easy fix so you may not have to drop your tank and change the pump. The holley pump is a walbro, they are know to be pretty reliable... but not impossible to be the pump either. Trace your lines back and change the filter first.
Kevin
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 18, 2005
  • Apr 18, 2005
Kevin
VERY TRUE.. Didnt' think of the filter... def. change that out if you haven't in a while.
bock
648
Montreal,Qc
Apr 18, 2005
  • Apr 18, 2005
Yes,i will change the filter first but it have about 2000 milles...
Went i turn off the ignition the pressure drop to zerp right there...
bock
648
Montreal,Qc
Apr 18, 2005
  • Apr 18, 2005
zerp=zero
J
jeffbigwood27
86
oklahoma city
Apr 18, 2005
  • Apr 18, 2005
Sounds like the regulator might be messed up and is bleeding off the pressure over 40psi. How high are you trying to get it 40 should be ok.
bock
648
Montreal,Qc
Apr 18, 2005
  • Apr 18, 2005
im runing #19 injectors with TFS-tw f-303 and gt-40 intake... i need 48-50 psi...
I tried my old regulator and i have the same problem...
bock
648
Montreal,Qc
Apr 18, 2005
  • Apr 18, 2005
ttt
J
jeffbigwood27
86
oklahoma city
Apr 18, 2005
#10
  • Apr 18, 2005
  • #10
I dont think it could be the filter bc if the filter is dirty it is more likely to cause the fuel pressure to drop while it is running. I would look at the pump being weak or make sure the gauge you are using works.
HISSIN50
34
129
Apr 18, 2005
#11
  • Apr 18, 2005
  • #11
have you tried carefully crimping the return line? no fuel in the vac line to the new FPR, right?
quick bleeding off can be from a bad FPR or check valve in the pump. good luck.
bock
648
Montreal,Qc
Apr 18, 2005
#12
  • Apr 18, 2005
  • #12
thre is no fuel in the vac line... i have tried 2 diffrent gauges:a little autometer scewed on the fuel line and a snap on gauge...
When yo say crimping the return line you mean kink it? to see if pressure build? and i f it does,what?
ALMOSTFINISHED
315
Westchester County NY
Apr 18, 2005
#13
  • Apr 18, 2005
  • #13
I'd like to know this too, Please post the outcome.
Nick
bock
648
Montreal,Qc
Apr 25, 2005
#14
  • Apr 25, 2005
  • #14
OK...
I did change the fuel filter.Same problem.
I tried crimping the return line,and the fuel pressure did not move of 1 psi.I did this for 30-45sec and nothing was moving,car idling.
the pressure is ajustable until 38-40psi.When i remove the vacc under 38psi the pressure drop as it should be.But when at 38-40 ,it dont move.
When hiting 38psi and still turning the screw the pressure stop going up.
If it was a bad injector....Do the car would run like ***** ? cause it runing really good.. but lean. thks
I
Idwitheld-1`
335
Portland Oregon
Apr 25, 2005
#15
  • Apr 25, 2005
  • #15
Looks like the pump to me.
HISSIN50
34
129
Apr 25, 2005
#16
  • Apr 25, 2005
  • #16
good call Id.
when the return line is crimped, the fuel should have bottlenecked and the pressure should have gone up.
Killer50stang
632
#17
  • Apr 25, 2005
  • #17
Go to 24# injectors, that will get you the fuel you need.
bock
648
Montreal,Qc
Apr 26, 2005
#18
  • Apr 26, 2005
  • #18
im changing the pump saturday...
will go with a walbro 255 lph (running a holley 190 now)
i will give you news guys!
thks.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Fuel Bad regulator diaphragm?
  • JD1964
  • May 20, 2025
2K
Fox 5.0 Mustang Tech Jul 16, 2025
JD1964
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
