fuel pressure regulator?
  • Thread starter Thread starter blkstangman88
  • Start date Start date Jul 12, 2004
blkstangman88
646
  • Jul 12, 2004
where is it and how do i sheck if its bad or not? i heard its right behind the tb, but where and what does it look like? and if i were to get a new regulator how do i switch/replace it?
SYLENTBUTVYLENT
136
Chicago
Jul 12, 2004
  • Jul 12, 2004
Your fuel pressure regulator is actually under and behind the throttle body. Find the chrome fuel rail and follow it back to the fire wall. The regulator should have a red vacuum hose connected to it. In order to change it, you may have to remove your upper intake manifold. Its three allen screws and its out. Go to www.jsperformance.com and pick up an Kirban adjustable fuel pressure regulator. You should also look into getting a guage so you can set the pressure to where ever you want it. www.50resto.com has a gauge and adapter kit that screws right into the shrader valve that is located on the fuel line.
blkstangman88
646
  • Jul 12, 2004
ok, now that i found it and i figure ill get a guage and new regulator, what does the fuel pressure have to be at?
rsw007
469
Lexington,SC
Jul 12, 2004
  • Jul 12, 2004
the best way to set it is on a dyno with air/fuel ratio reading. it all depends on your mods h/c/i
blkstangman88
646
  • Jul 12, 2004
well right now all stock on the h/c/i setup
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Jul 12, 2004
  • Jul 12, 2004
You seem to be pretty stock. Stock fuel pressure is 39. I would suggest that.
93 teal terror
971
62
69
Durham N.C.
Jul 12, 2004
  • Jul 12, 2004
http://www.cardomain.com/memberpage/461740/4
blk92stangg
583
Hawaii
Jul 13, 2004
  • Jul 13, 2004
BTW I got mine off without taking off the intake. Instead I took off the EGR and took my time. I also had to cut down a hex wrench to get to the left bolt.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
T
Engine Need help figuring out misfire and backfire
  • trystancounts
  • Sep 25, 2025
Fox 5.0 Mustang Tech Sep 26, 2025
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
