vristang or millhouse or anyone with some knowledge i found this info on the net. about an adjustable fuel pressure regulator is this info. accurate. can you add or take away from this article.
Q: Do I need an adjustable fuel pressure regulator?
A: If everything is calibrated right, the stock regulator works great and there is not a lot to be gained by changing it. Small power gains can be made by adjusting pressure while dyno tuning, but that is about it. For the most part I recommend keeping the stock regulator until you actually need an adjustable one. However there are 3 circumstances where an adjustable regulator can be very useful
(Really the only time an AFPR is effective, is if the AFR is straying from stoich. Using an AFPR any other time, will simply invoke the Adaptive Fuel Strategy...)
1) The MAF calibration is not perfect.
Pro-M and C&L meters flow more air, and are necessary for high output cars, but it is unfortunately all too common for their calibration to be off a little (This error can account for about 50% of the Adaptive Strategy itself, even with 'good' meters). Adjusting fuel pressure on a dyno or with a wideband 02 is an effective way to compensate (if pushing the AFR back toward stoich). The ECU can only correct so far by itself (+/- 12.5%). If you've ever monitored the 02 voltages over long periods of time you will see that the fuel pressure will affect the 02 readings even after many driving cycles where the ECU theoretically should have been able to re-trim the fuel settings to correct the air/fuel ratio. The ECU correction is just not that precise and is also limited in range (The ecu can take quite a while to fully 'adapt'. Changes are only made to the Injector pulsewidths after the ecu sees a variation from stoich for a determined time frame). An adjustable fuel pressure regulator will improve performance in these circumstances if tuned properly.
2) High output fuel pumps cause “pressure creep” at idle.
If you are running a 255 lph or larger pump and a stock regulator, you may have noticed that fuel pressure at idle is higher than when driving at part throttle. This is because the pump pumps more fuel than can free-flow through the regulator. Under load the engine uses some of the excess fuel, so the regulator functions normally. But at idle the fuel is not needed and has return to the tank through the regulator. Pressure climbs above normal because the fuel flow back to the tank is restricted by the regulator fittings. This causes a rich condition at idle, wasting fuel, increasing emissions, and shortening the life of the spark plugs. The fittings on the newer versions of the Kirban regulator have a larger internal diameter. This eliminates the restriction, allowing the un-needed fuel to free-flow back to the tank for better control of fuel pressure during light load conditions.
(This is complete hogwash... For the 6 mo. before parking my 408w for the rebuild, I ran on a 255lph pump and factory regulator. As far as I know it was the original regulator. If you compare the fuel pressure during idle to part throttle cruise, you will see a fuel pressure difference. This is due to a variation in the manifold vac signal though)
3) Speed density cars are easier to tune with an adjustable pressure regulator.
The ’86-89 Mustang and 93-95 Lightning use a speed-density (engine speed + air density) program to calculate the fuel needs of the engine. Unlike Mass-Air systems, the ECU has no meter to measure the mass of incoming air. When modifications are done to increase the volume of incoming air you can quickly exceed the ability of the ECU to compensate through 02 feedback alone. This is especially true of wide open throttle performance because the ECU ignores the 02 sensors at wide open throttle. An adjustable fuel pressure regulator is very useful for tuning these cars. In the late 1980s before Mass-Air was installed in the Mustang, and before computer chips were available, several racers were running low 11 second quarter mile times using only fuel pressure and a timing light to tune the car. (This method of tuning is still not 'ideal' as it leaves room for error in the 'Load' calculation. Load is used to calculate Injector Pulsewidths and Ignition Timing. So, if the Load number is off, then so is the Ignition Timing and Injector Pulsewidth. I cannot say how much of an error this would create, or if it could be compensated for with base timing and fuel pressure. However, it is not 'ideal'...
The same error in the Load calculation is created when using a large fuel injector with a calibrated MAF meter. The larger the injector, the larger the error in the Load calculation.
Again, I'm not yet sure how much of a problem this may cause, as I have not been able to test anything lately...)
