fuel pressure regulator
derrick gil
67
Hi guys. I recently put a 331 stroker in my 89GT. It has a 75mm. mass air flow, 70mm. throttle body, holley systemax intake, AFR 185 heads, 30# injectors, cold air intake, off road h-pipe, and 3:73 gears. I'm about to put a walbro 255lpf fuel pump and an adjustable fuel pressure regulator. I'm just wondering what I should set the regulator at. I'm going to get it tuned, but I want to break the engine in first. Any thoughts on what pressure I should set the regulator would be very helpful. Thanks
Get one of your buddies to ride along with you. Find a level stretch of road where you can do some testing. Watch for the wind speed and direction, it can have a definite impact on your test results.
Don't choose a speed range that will make you shift gears, the shift quality & speed will affect your results. Use 2nd or 3rd gear and do a run from 2000 RPM to 5800 RPM. Call out the RPM as it increases and have your buddy record it and the elapsed time. If you have one of those cheap digital watches like I do, a stop watch is built in.
Start the fuel pressure at 36 PSI, vacuum off and make a run. Turn it up to 37 and make another. Be sure to reconnect the vacuum every time you set the pressure. Keep turning up the pressure and making runs until you notice a drop off in time. If your bud was careful to record the results, you'll have a nice chart to use to find the optimum pressure.
