liljoe07
5 Year Member
Posted via Mobile Device
The blue/orange wire at the relay should be the ECM ground.
Remove any of the jumpers you installed on the test port, hook a test light to a 12v source and the blue/orange wire. Turn the key on, the test light should come on, then go off.
See what happens. If it doesn't work, then test the continuity from PIN 22 at the ECM to the orange/blue wire.
Make sure the inertia switch in the trunk is push down first.
