Fuel Pump vs. boost
I know that this question has probably been asked at least a million times in one form or another, but I'll go ahead and repeat it.
How much boost will a factory '93 mustang fuel pump take? Basically, what is the ratio of LPH/GPH/etc. per PSI of boost
not very much, if you dont change it you up your chances for the KA-BooM factor... I think the ratio is 10psi of boost to 1 psi of fuel, but i'm probably wrong it might be backward...
Thanks for the info guys. I believe that the ratio of fuel to pressure increase is 1:1 with a minimum of 45psi fuel. Due to a tight budget I'm goind to run with the stock pump, maybe for about a month until I can afford a 255LPH pump. I'm looking at either BBK or Granatelli. Possibly Holley too, because they're all about the same price.
Thanks again
