fuel pump wiring blues
quadstang
Tomahawk, WV
whats up guys!
I have an 89gt and i'm doing a EFI to carb conversion and I am running an inline electric fuel pump. I need some help with the wiring so I can get it to work again with the ignition switch. The wiring help that I have says that I need to look for 2 wires that are at the 2 wiring harnesses located near the brake booster. (that is where I unplugged the EFI harness and pulled that darn thing out) Has anyone ever done this before and could you give me some helpful hints?
THANKS!
-D
You find the plug that the pump harness plugged into. You will use 2 wires from it. had to do this on the 66 when it was converted to efi with a inline pump. I dont recall what color wires but I think one was ground and the other was switched 12volts
the wiring explanation that I got off of fletchs' website says that there are two wires on the black harness that I need to tap in to. The colors of the wires are not there? Its supposed to be a tan/lt. green wire for ground and also a solid red wire for 12v. I traced the wires from the fuel pump on the schematics out of a Hayne's manual but it says that they stop somewhere under the dash close to the fuse box. But fletch says that they are on the black harness under the hood. Got me.
