  • 2.3L (N/A & Turbo) Tech
Fuel Pump
  • Thread starter Thread starter SVOconvLX85
  • Start date Start date May 13, 2004
SVOconvLX85
251
Vegas, for a while...
May 13, 2004
  • May 13, 2004
I noticed the other day that their was a hiss when I got out of the car. It was really loud and I thought it was a tire leaking. As I got closer, I noticed that it was the external fuel pump on my SVO. It is the higher rate pump and I was just wondering if anyone knows what is making the thing still run. Is it in the ignition. This is probably why I go through a lot of gas.
Another thing, on the SVO's, can I just get a 255 lph pump and mount it in the tank and delete the external one? Or maybe justa 5.0 in-tank pump will do? Any suggestions? Thanks
P
Pro-Hawk
971
West Texas
May 13, 2004
  • May 13, 2004
Well I can't help on the other part of this but I do know you can replace the external pump with a intank pump. From what I understand the fuel pumps amd FPR are the same on a 2.3L and 5.0L. I would either run a 190 ro a 255 lp, I think a 255 will need a adjustable FPR. If I remember also that a 190 will support 350 hp and may not need a adjustable FPR. I got a chart on it some where and will post it when I find it. When you go to replace the intank pump you will need to run a different ground but I'm not sure how its done. Check out SVOCA they got a few post on this. Now when you go to tank that brass lid off the fuel tank becareful because sparks could well I'm sure you can figure that out Here is a link and hope it works.
http://www.svoca.com/forum/showthread.php?s=&threadid=2889&highlight=fuelpump
notched86
305
Ruckersville, VA
May 13, 2004
  • May 13, 2004
The stock fuel pump on my '89 2.3 is loud as hell. That thing whines.
Stinger
7,754
24
118
Basehor (Kansas City), KS
May 13, 2004
  • May 13, 2004
Nope...no fuel pump requires an adjustable regulator.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2026
Ryu
New fuel pump relay
  • Scrapla347
  • Nov 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 8, 2025
Scrapla347
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
