Fuel Pump
  • Thread starter Thread starter haoleboy72
  • Start date Start date Jan 16, 2007
H
haoleboy72
60
Hillsboro, OR
Jan 16, 2007
  • Jan 16, 2007
Quick question on fuel pumps. I was searching ebay for a 255lph pump and found some Walbro 255, but in fine print in said not for nitrous, supercharged or turbocharged motors. Has anyone else seen this before? Can anyone tell me why? and what pump I should buy if I plan to eventually supercharge my car?
Thanks,
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Jan 16, 2007
  • Jan 16, 2007
Probably because the fuel pump you were looking at wasn't a high pressure fuel pump.
In either case you can make any fuel pump work with any set-up... low-pressure in-tank/ high pressure boosta-pump.. and etc.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Jan 16, 2007
  • Jan 16, 2007
Gotta find the 255lph that runs HIGH psi, then get and adjustable fuel pressure regulator and spray away!
5.0 Nostalgia
904
CT
Jan 16, 2007
  • Jan 16, 2007
Get the Holley 255lph. There are two versions, one with higher pressure output for forced induction.
Here's a link:
http://store.summitracing.com/partd...4294924930+4294836951+400178+115&autoview=sku
Note: maximum pressure is 110psi instead of 90psi.
HISSIN50
34
129
Jan 16, 2007
  • Jan 16, 2007
FWIW, the Holley is probably still a Walbro.
As said, the non HP versions don't keep up enough volume/pressure at higher RPM. Walbro has charts on their website so you can see what we're talkin about.
Good luck.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
New fuel pump relay
  • Scrapla347
  • Nov 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 8, 2025
Scrapla347
