Fuel Tank Issue
And in my opinion, Ford shouldn't be able to get away with leaving them unrepaired. It's not only ridiculously inconvenient, but it is also a safety and environmental issue (at least in the cases where it not only shuts off but also spews out).
Believe me, I have tried pumping slower. If you pump slower, the pump will not click off, it will merely pump the fuel right out of the tank onto the side of your car and then onto the ground.
It's also a gas station issue. The newer pumps are designed to throw gas into the tank faster to get more customers through. Older gas stations using older pumps will suffer less because they're designed to fill slower.
I have to call :bs: on that one. I tried using the exact same gas pump with the 07 that I routinely used with my 96 Cobra. The gauge indicated that it was down to under 1/4 tank. The car took 7 gallons and no more. I ended up having to move to another pump to finish the fill up. Never had this problem with the 96 at the same pump.
So you already had TSB 05-4-8 performed in 05. NOW, you take it in and after 5 days and a 20 mile joy ride (check the in/out mileage on the order 7211 IN - 7231 OUT. Come on.. They didn't drive that far in my GT when it had cracked control arms.. pfffttt WTF?) they tell you this is "normal"....
I find it difficult to swallow that the federal government with their tight hiney emission controls + vehicle warranty would accept this as being a "normal characteristic" for any vehicle.
You have two ways of handling this based on this affecting you only or this affecting many consumers as well as the environment. 1. The grand pro-active butt kicking for the masses would be write Ford Corporate and send a copy of the work ticket, provide a copy complaint to the NHTSA
http://www-odi.nhtsa.dot.gov/ivoq/
as well as the EPA.
2. The proverbial "Just Me" approach will be to contact the GM of the dealership and ask he/she HOW is a vehicle that is spewing fuel and vapor emissions due to a faulty vapor venting system inside their ill-designed saddle tank a "normal characteristic"? Let the GM know that you would be interested to see how the federal emission warranty and laws would read their interpretation of this "normal characteristic".
Either way, hold tight and your fuel tank should be fixed in time. This will not fly - NO WAY.. Not on my watch. LOL
Yell if you need help. I have an arsenal of big words and lofty intellectual threats at your disposal.
~J~
Edit Add: Right Now Ford has a similiar issue pending on the Ford Taurus (See Below)
Report Date : February 3, 2007 at 01:29 AM
SEARCH TYPE : VEHICLE
YEAR : 2005
Make : FORD
Model : TAURUS
Results : 1 | All records displayed
NHTSA Action Number: NHTSA Recall Campaign Number:
DP06005 N/A
Make: FORD Model: TAURUS
Manufacturer : FORD MOTOR COMPANY
Year : 2005
Component :
FUEL SYSTEM, GASOLINE: DELIVERY
FUEL SYSTEM, GASOLINE: DELIVERY:FUEL PUMP
FUEL SYSTEM, GASOLINE: DELIVERY:HOSES, LINES/PIPING, AND FITTINGS
FUEL SYSTEM, GASOLINE:FUEL INJECTION SYSTEM
FUEL SYSTEM, GASOLINE:FUEL INJECTION SYSTEM:FUEL RAIL
FUEL SYSTEM, GASOLINE:FUEL INJECTION SYSTEM:INJECTORS
FUEL SYSTEM, GASOLINE:STORAGE
FUEL SYSTEM, GASOLINE:STORAGE:AUXILLARY TANK
FUEL SYSTEM, GASOLINE:STORAGE:AUXILLARY TANK:SELECTOR DEVICES
FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:MOUNTING
FUEL SYSTEM, OTHER
FUEL SYSTEM, OTHER: DELIVERY
FUEL SYSTEM, OTHER: DELIVERY:FUEL PUMP
FUEL SYSTEM, OTHER: DELIVERY:HOSES, LINES/PIPING, AND FITTINGS
FUEL SYSTEM, OTHER:FUEL INJECTION SYSTEM
FUEL SYSTEM, OTHER:STORAGE
FUEL SYSTEM, OTHER:STORAGE:FUEL GAUGE SYSTEM
FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY
FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY:FILLING/CHARGING
FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY:MOUNTING
FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY:PRESSURE RELIEF DEVICES
Date Investigation Opened : December 4, 2006
Date Investigation Closed : Open
It is obvious that no one has issued a formal complaint with the NHTSA. (There is no option under their database query for the 2005-2007 Mustang.)
Hit the link provided above and fill in the quick online complaint form. This will start the formal process which eventually ends with a Mandatory Recall Order issued to Ford.
I recommend each member who has taken their vehicle to have the Technical Service Bulletin performed do this.
Let me know if you guys need additional assistance with this problem. :flag:
~J~
I just got a call from Ford. Apparently they have now done their research and have determined that they are not going to make any attempts to fix my vehicle.
They said that if they put another fuel tank on the car that there is no guarantee that I won't still have the problem and for that reason, they are not going to do it.
She suggested that I either select a different gas station, or pump the fuel slower.
By the way, pumping the fuel slower DOES prevent it from clicking the pump off... however, it still doesn't allow the fuel to flow into the tank. Apparently, if I pump it slowly the fuel reverses directions and pumps out onto the side of the car and down into the parking lot.
However, both the dealership and the Ford representative said that this is a normal characteristic for this vehicle and is not indicative of any problem with the car.
For now, that's where I am.
I did file a complaint, as you suggested, though.
~J~
Oh no, you didn't?!? Let's see how long it takes for some knuckle-head to flame you for trying to cause more problems for Mother Ford!!!
Jfrayzier - that response from Ford is ridiculous! I cannot believe that they said that to you! Who has the cahones to get on the phone and say something like that? "Normal behaviour"? In which sick, fantasy-world is this "normal"?:bang:
So if a group of people were to take 20 different make and model vehicles to the exact same gas station using the exact same pump as one of your Stangs usually has this problem and ALL the other cars fill fine with absolutely no problems will Ford still make that ridiculous statement, "Not being indicative of any problem with the car"???????? Are they setting themselves up for another "Firestone" incident??????
:rlaugh: Come on "My Brother from a Different Mother". :lol: I used to travel around with mom and dad sitting in the back of a Pinto. :rolleyes: This is an issue that needs to be resolved and the Complaint process is the only way it is going to happen.
Don't hate the Player - Hate the Game. :p
You sure can't say they aren't being consistant with the BS. I took my '06 in two weeks ago and got the same answer. They put in 8 gallons of fuel and said that it was within specs for this vehicle. Then gave me the Ford issued bulletin saying to try a different station and to pump slower. It's embarrassing to get fuel here in Oregon as we have full service stations only. I usually only get $10 at a time so the poor bastard pumping the gas isn't stuck holding the nozzle for ten minutes while the other people glare.
Alright Fellas,
I viewed the complaints issued so far and there is one thing that I noticed. If I was the NHTSA complaint reviewer, I would not escalate this issue as a SAFETY concern. For those who fill in the form from here forward please ensure you indicate if the fuel has backed out of the inlet tube over the side of the vehicle.
How the complaints are worded will dictate if this issue is seen as an "inconvenient" saddle tank design or one that may cause a safety and/or environmental concern warranting a mandatory recall order.
THANK YOU fellas for fighting the good fight and working together to get this issue escalated.
A friend of mine just said that if I fill whilst wearing RED SHOES, turn the nozzle UPSIDE-DOWN, only fill at AMERIGAS gas-stations, never let the tank get below 27% full (there goes my trip to Vegas:mad: ), and STROKE the vapor-hose, all the while whispering "Oo, take it baby. You know you want it. Oh, yes. You LIKE it!", I should be ok.
I'm off to find me some red shoes...
:lol: :lol: :lol: :lol: :lol: :lol:
You need help my friend. :D
When I asked the lady at Ford virtually the same question, yes, it is still not a problem with the car.
I tried fueling with the pump upside-down (NASCAR-style) today. No premature shutoff, which is good. But it did pump about $0.60 worth of fuel onto the ground before it did shut off. Still spews the fuel that way I guess.
