full suspension: suggestions/thoughts?
AmBo
1,027
New Jersey
Hey all! Well, about a year ago I dropped my stang and I was a typical broke college student. So I only bought the $220 springs and dropped it. Well, now a year later and many hours of driving what feels like a bucking bronco, I have the money to truely finish off my suspension. This is what I have in mind:
Bilstein Heavy Duty Shocks/Struts:
Front: http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=89
Rear: http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=90
Upper/Lower Control Arms:
Steeda or MM? MM doesn't make Upper Control arms while Steeda does. So should I just buy Steeda Upper and Lower Alluminum control arms? Also, how hard are these to install?
Subframe Connector:
MM Standard Length: http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=332
Do I need full or standard length subframe connector? Is this all I should do? Any opinions? Suggestions? Tips? Thanks
the welding is going to cost just about the same on either subframes.... personaly i'd get the MM full length XL subs that they just released a few weeks ago.
the bilstine is a good choice. I'd go with steeda aluminum lowers to match with it. you might want to consider a panhard bar and torque arm and remove the upper control arms... lil more money, but it would be a "complete" system and no longer need anything for the rear suspension at all.
just a few thoughts.
Torinalth
i cant help with pulling out arnold... but the panhard bar is a bar that keeps the axle from moving from side to side. the torque arm prevents axle wind up as well as keeps the car flatter under hard accelleration. the upper control arms try to do both (axle wind up and side to side movement) and typically fails, even with aftermarket parts. maximum motorsports has a bit better explanation on their site. i'll be going this route. getting springs/shocks/LCAs, then get the panhard bar, then the Subs and torque arm.
read up on MMs site. LOTS of great information, and to alot of people it is the best company for stang suspension out there. i tend to agree... but its my personal opinion.
Torinalth
Hey, I'm right there with you. I put on Eibach pro kit springs around a year ago as well and the ride is noticeably getting harder. How much money are we looking at going the panhard bar way? I was just thinking of throwing on some good shocks/struts and see what the difference was. What do you think?
Delacruz, that was my idea as well. But I'm going to get lower control arms as well. The Bilstein shocks and struts are $465, and the lower control arms are like $180ish. So plan on spending roughly $650 for this stage.
How much are panhard bars?
bilstiends are great choice.
don't buy upper control arms. there is a reason MM does not make them. Steeda just makes the equivelend of a boxed stock on basically. I think MM recomends rubber uper bushings as well. pay the shop that does you subs to box it in if you care at all.
now when you do lower control arms if you don't want to go all out and buy a panhard rod you can get more positive axel location out of you control arms as well. I went will MM spherical amrs and it helped alot. global west does this on thier cars and does not add panhard rods and get pretty good handling. so I tried it.
Do full subframes.
I would like to add the parhard rod and torque are to my car eventually but if you like me at all you have to kind of work in stages due to cost.
another aproach could be to buy the panhard rod and box the stock lower control arms for starters to save money.
This is great advice. Funny, I was just thinking about this all week. I just got in my shifter and was thinking what next? After riding around it was OBVIOUS what was next. This is cool. There's a suspension shop down the highway. I think I'll go run all this buy him and see what kind of deal he'll hook me up with. But you're right, it most definitely will be a little at a time. :nice:
I bought the MGW shifter after MUCH reading and research. It's sitting on the floor of my living room just waiting for the weekend. I'll let you know how it goes, but every thing I've learned leans towards and easy install and a GREAT mod. I'll let you know.
Exactly!! I went through tons of those and MGW came up on top. Sounds like there's a few excellent ones (MGW, Tri-Ax, Pro 5), but to me it sounds like MGW is the ****zle right now. Newer and more improved on. I'm about to find out! :flag:
What is your application? What are you trying to acheive?
Before you start piecing together a suspension package for your car, think long and hard about what you are trying to do...
Drag racing? Road racing? Better street handling? Smooth ride?
Each will have a different answer, from components to spring rates.
Don't mix and match as you will end up with a screwed up car. Figure out your application and get your components from one manufacturer as they will have (or at least should have) optimized their packaged systems.
I'm going towards the road handling/racing side. As such, I'm going with the Griggs Racing TA/PB setup. Another good option would be Maximum Motorsports.
If drag racing, I'm sure you could do a search to see who are the best in that arena.
Good luck,
Norm
p.s.
As for shifters, I used to own a Pro 5.0 and now have the MGW. I can say the MGW feels so much more sophisticated than the Pro 5.0. The MGW has super short and precise shifts, the handle can be angled to your need, and it's extremely smooth and quiet. Don't get me wrong, I really liked my Pro 5.0. The only two problems I had with it was that it was very loud (transmits a lot of tranny noise into the cabin) and the stock handle was way too short (easily fixed with an aftermarket handle). Good thing is that I sold it for what I bought it for...
On a side note, the MGW comes with a gasket that you can use in lieu of RTV. Much easier to remove for tranny oil changes or service...no more falling into the back seat as you break the RTV seal gluing your shifter to the tranny!
Here are a few pictures of the MGW shifter. Note that I have the early design of the handle assembly...
Thanks. You make sense. What I want is street handling/smoother ride. I ride around in L.A. and a lot of the streets are very bumpy and have pot holes, etc. Pot holes and can avoid, but the screwed up streets I cannot. When I hit these areas a rattle and bounce all over the place. On good to moderate streets the car handles good. It's these bad areas I would like my car to handle better. Really...my car literally will bounce all over the road.
I installed Eibach Pro Kit springs about a year ago. I was thinking that by installing some good shocks/strute (Eibach has a set that they say is made to go with the springs) or another brand and maybe a stabilizer bar. Eibach actually has a "kit" that includet all three of these things. Sounds to me though like L/U arms and panhard bar are needed? For what I want, what do you think?
(sorry for the spelling. I was in a hurry.)
I went with MM adj. upper and lower control arms. They are really great, and they make the car handle allot better. I alreay have the Bullitt's suspension to start from. The uppers made the ride rougher, so I would avoid uppers unless your into drag racing. My eventual goal is a car that hooks well on the track, and can still handle on the street. I sacraficed softness/noice/comfort a little when I went with the uppers.
Mike
OK. So I have the stock shocks on and I should have replaced them when I lowered the car, but I didn't. It didn't take long to figure that out. So those need to go and so I should get lower control arms. Sway bar? Can you suggest a good shock and LCA for my needs? I like to run my car to max, but I wouldn't say I drag race or even take it to the track. I like the power I have but drive a lot around the city and would like to improve the ride. That's my priority right now.
For potholes and rough surfaces...that's a hard one. If you lower your car and increase your spring rates, etc., your car's NVH will go up. I'm not an expert with spring rates and bump/rebound settings for your dampers so I can't comment on what an optimal setup would be (perhaps others can help here). If Eibach has matched dampers (bump/rebound valving matched to your spring rate and vehicle), that may make the ride much more civilized since your current (stock?) dampers aren't up to the task. Another option would be to find out the spring rates of your Eibach springs and get some dampers valved to match (probably more of a PITA).
Good luck,
Cool. I'll look into the Eibach dampers that are geared to work with the springs. I think Eibach has worked these two in combination so they will work better together as opposed to having two different manufacturers. Just wanted to hear from others. Thanks again. :flag:
