G-Bar Suspension
  • Thread starter Thread starter SnakeStang65
  • Start date Start date Nov 1, 2006
SnakeStang65
160
Jasper, Indiana
Nov 1, 2006
  • Nov 1, 2006
Has anyone installed the TCP G-Bar suspension in their 65-66? If so, with the addtion of mini tubs, what would be the maximum tire size? It appears to be about a 295 or 285 on a 9.5 inch wheel. What are the overall comments about this suspension also? Photos also appreciated...
John
Swede958
712
Austin, TX
Nov 1, 2006
  • Nov 1, 2006
HAHAHAHA I was waiting for something like this to come out. That was the first thing I thought of when I saw Air Ride's setup- forget the bags and throw some coil overs on it. Apparently at least with bags it rides pretty well.. the design is sound enough.
As far as clearance... I would go with only about 1" more maybe inboard because it still uses the stock location for the spring mounting plates.
68FBJJZ109
357
Easton, PA
Nov 1, 2006
  • Nov 1, 2006
You gain a little clearance, though not much like he said it uses stock mounting points, I ditched my air ride because of it.
iskwezm
4,159
20
79
Rowland Heights,California
Nov 2, 2006
  • Nov 2, 2006
i was thinking about that, just for the height adjustment and ride quality
Bullitt
Packin' Heat
2,743
Houston, TX
Nov 3, 2006
  • Nov 3, 2006
Eh, parts are good parts are bad.
Basically looks like a marginally improved 4 link off of a 79-04 Mustang. If you've driven a fox or an SN95 mustang in anger you know what a mess that is.
basically you're going to run into issues with the upper links binding. a panhard will help a lot, but it's hard to make that problem go away. if you don't drive hard (ie-autocross or open track) then you'll probably never notice the difference.
SnakeStang65
160
Jasper, Indiana
Nov 3, 2006
  • Nov 3, 2006
The main intention is to have an improved suspension over the leaf springs, along with the ability to increase tire width for traction. The car will not be driven to great extremes seing how it is mostly a show/touring car. If I can get it to handle as well as my 03 Mach, I will be very happy.
John
SnakeStang65
160
Jasper, Indiana
Nov 3, 2006
  • Nov 3, 2006
The car today has Cal-tracks on it. The bar for the Cal-Tracks are in the same location as the bar would be for the lower control arm. Using this as a reference, I should be able to increase the tire width by about 2 inches before I have an interference with the lower control arm. Using these same measurements, it looks like I will have to move the rear wheel house over about 1 inch at the top and about 1.5 inch in the front for the additional clearance. I should safely be able to increase the wheel width to 9.5 inches and possibly 10 inch. Tire width maximum appears to be about a 305 keeping it completely under the car and in the wheel house after the mini tub. Obviously I will have to go to a custom back spacing, but that is not a concern as if I go this route, I will narrow the rear axle at least 1 inch on both sides from stock.
John
allcarfan
The Answer Man
2,458
North Atlanta
Nov 3, 2006
  • Nov 3, 2006
If you can hold off a week or two in purchasing this.....
One of my suppliers just designed a setup very very similar to this one. It requires a little welding. Complete, adjustable coilovers, replaces shocks and leaf springs. I am not advertising here, but my supplier is currently installing this setup on a 65 mustang in Cali. They dont know what tire size they are going to be able to stuff under there yet, but I can let you know if you are willing to wait.
SnakeStang65
160
Jasper, Indiana
Nov 3, 2006
  • Nov 3, 2006
Keep me posted. I am definitely interested.
BLK91LX1uponu
172
Sacramento
Nov 28, 2006
#10
  • Nov 28, 2006
  • #10
Any more news on your buddies kit, Allcarfan?
65mistress
405
Generica USA
Nov 28, 2006
#11
  • Nov 28, 2006
  • #11
That would be interesting to hear what the outcome of that install was. Possibly a write up of it would work too.
allcarfan
The Answer Man
2,458
North Atlanta
Nov 28, 2006
#12
  • Nov 28, 2006
  • #12
no follow-ups....i will see about it this week.
joncash
just high enough to be functional
756
The USA's peen
Nov 28, 2006
#13
  • Nov 28, 2006
  • #13
Well I'm interested. Subscribing.
BLK91LX1uponu
172
Sacramento
Nov 29, 2006
#14
  • Nov 29, 2006
  • #14
Thanks...
I already have my watts link but I am leaning toward a coil over setup now.
allcarfan
The Answer Man
2,458
North Atlanta
Dec 1, 2006
#15
  • Dec 1, 2006
  • #15
Well,
It seems like they reply to all of my emails except the one regarding the tire/wheel combo on a 65/66 mustang with their setup. Maybe they have not gotten that far yet. Regardless...I will be ordering one of their setups eventually.
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
Progress Thread BluePrint 347 long block engine swap
  • Sparky714
  • Aug 2, 2024
  • 7 8 9
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 8, 2026
Sparky714
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
