G-Force Trans! Roughly 3k. NO track time
Pokageek
2,767
MA, USA
G-Force Trans! NO track time. TUFF trans. 94/95
About 3k miles. This is a Seriously BEEFED trans. It will fit in your stock t-5 location with NO modifications unlike the other transmissions out there!
It has all the bells and whistles including thicker main shaft & re-enforced casing. Syncho gears for easier shifting. My builder Rick Hawver recommended this trans for its durability. Its a bit too whiney for me and I don't need the .64 5th gear. Helps on the hwy tho with 20mpg on my 414 went I dont get on it. Its great for folks with steep rear gears but drive hwy too! 26 spline. $1700 sells it. This is not the standard trans. It has the upgrades. $2200+ new with the options. Save $500.
Here's what I could dig up. 2.94, 1.94, 1.34, 1.00 ratios in gears 1 thru 4, and .64 5th gear. It says .63 on their site but .64 on my receipt (packing list).
294 PRO/GF T5 Synch 9310 Alloy gear set.
"NOTE: This style transmission gear is STRONGER than a factory GEAR and may generate more gear noise when driven on street."
T5 W/C Complete Rebuild & small parts kit.
T5 Aluminum Steel retainer w/seal
Labor
T5 Cluster support plate
2 HD SYNCH High Alloy Shift Lid Plates (fits 1-4) each
T5/T45/T56 fits slider alloy metal key (set of 3)
PLUS 10.5" Blue Printed HI REV p/p (thats the hardened casing according to them) there is no "gforce" case.
The trans will work with any 87-95 HOWEVER, the INPUT shaft and bearing retainer would have to be changed for a 87-93. Thats $75 install, $49 bearing retainer and $295 input shaft. 87-93? My advice, go buy it directly. .. dam 94/95's. Sorry.
