Gas guage don't work
  • Thread starter Thread starter MorbidGTVert
  • Start date Start date Feb 27, 2004
MorbidGTVert
50
Melbourne, Fl.
Feb 27, 2004
  • Feb 27, 2004
since i bought the car the fuel guage doesn't work. what i wanna know without taking it to a mechanic is how do i test it with out taking the tank off. this sucks going offthe trip meter at 100 miles i get paranoid and fill it up. i just wanna know if it is the guage or the setup in the tank any suggestions will be helpful
J
jerry beach
2,671
Ocala,FL
Feb 27, 2004
  • Feb 27, 2004
If your needle is pointing at full most all the time, like mine, It is the sender in the tank. I ohmed out my sender while I had the tank out of the car, and mine is trashed. It reads "open" in most positions. The cheapest I could find one was $80, so I didnt fix it. I just set my trip when I fill up and drive for about 200mi., at this point I have burned about 10 gallons, or 1/3 of a tank. The tank holds a little over 15 gallons, depending on who you ask.
T
thompsonsd
144
Southern Maryland
Feb 27, 2004
  • Feb 27, 2004
Man, you guys get good MPG's... I only get 10 mpg driving nice. Anyway, here's my experience with stock sending units and fuel pumps. When I hit around 160,000 miles my sending unit went out, then at around 185,000 miles my fuel pump went out. Then at about 187,000 miles my clutch cable snapped. After that I just tore everything apart and rebuilt it all.
MorbidGTVert
50
Melbourne, Fl.
Feb 27, 2004
  • Feb 27, 2004
when the car is off key out the gauge says 1/4 full and when you stick the key in the ingition it goes strait to E. some guy at the junk yard said it was the gauge but he drives a camaro and it might be different.
86Five-0
806
New Jersey
Feb 27, 2004
  • Feb 27, 2004
I've had experiences in the cold weather were my gauge would stay at E right when I start the car up. I got out and pushed down on the rear of the car to bounce it around some and then the gauge started climbing. Maybe it could be stuck? Try bangin the tank with a rubber mallet a little bit. Right around the middle of the tank and see if the gauge moves around at all. $80 seems alot for a sender, When I replaced my fuel pump I was debating on whether or not I should change out the fuel sender but didn't. No problems so far(knock on wood).
Black331Stang
1,485
Long Island, NY
Feb 27, 2004
  • Feb 27, 2004
autometer fuel gauge. How do they hook up anyway? i know some have senders and some dont
J
jerry beach
2,671
Ocala,FL
Feb 27, 2004
  • Feb 27, 2004
If you take off the right rear wheel, you can access the electical plug for the tank without removing anything else. Unplug it and hook an ohm meter to the wires for the sender. If it reads "open" at anytime, the sender is junk. Only problem is you wont be able to move the float through its range to see if it works properly at all fuel levels. there are 2 wires going to it and 2 wires going to the pump through that plug. The sender wires should be pink/black and black. If not they will be yellow/white and black.
Electrical Oil Pressure Gauge IN Dash Cluster Unresponsive
  • Nine Finger Wrenching
  • Jan 7, 2025
Fox 5.0 Mustang Tech Jan 8, 2025
85GTStangGuy
T
2000 mustang guage test
  • tankthomas
  • Aug 13, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 13, 2024
tankthomas
T
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
