Ram5773
The fuel pressure sensor hmmmm. I look into that, but it seems to be average for our cars to get around 190 to 230 miles out of a tank. Anyone else agree?
Ram5773 said:Do you think the mix changes for the guys down in the southern states?
Ram5773 said:The fuel pressure sensor hmmmm. I look into that, but it seems to be average for our cars to get around 190 to 230 miles out of a tank. Anyone else agree?
Kilgore Trout said:I get about 8 miles to the gallon in the city and about 22 miles to the gallon on the highway. I love it, if I want fuel economy I will drive my Civic.
I'm at 56k, so time to switch the plugs as well. That might help a bitRam5773 said:The one thing I have noticed with our cars is that the intown and highway have a good difference between the two. Most cars have a difference of maybe 5 miles to the gallon but our cars have a little bit larger of a jump. Kilgore milage is a prime example
Kurgan said:Something else I thought of..
If your fuel pressure sensor (on your fuel rail) is not reading properly, the PCM will increase the fuel pump duty cycle increasing pressure in your fuel rails, which causes your injectors to spray more fuel than they should. You can get a dealer or tuner to read the fuel pressure readings from the PCM using a scanning tool or OBDII datalogging tool. If this happens to be the case, simply replacing the sensor would fix the problem.
Check out this article for some diagnostic tips:
http://www.aa1car.com/library/returnless_efi.htm
Dragstr05 said:This I would have to say is improbable, because it would cause a change in emissions characteristics and would trip the CEL.
Its very likely your problem is only in the gas. If there was more fuel being dumped in than normal, you would get a CEL for bank 1 or bank 2 lean. If it was air filter related as mentioned, I doubt it would cause that kind of drop. I believe colder, or cooler in your case, temperatures and the supposed reformulated gas are to blame.
squeak93 said:300 miles per tank....![]()
More like 180 if I'm nice to it, Damn 4.30's and ALL CITY driving.
