HISSIN50 said:That's a new one on me. I prefer to use what the car manufacturer recommends (on the door sticker, in the owners manual, etc).![]()
RsStanG1987 said:I cant believe the horrible mileage people get with a stock stang and gears on the highway its just weird. I had 3:55's and a lead foot and constantly got over 30mpg on the highway. I also inflated my tires according to the door tag like hissin said.
I would start on a completely full tank. Id fill up then set the trip odometer then at the next gas stop i would take the amount of gas it took to fill it divided by the ammount of miles i put on. I went from Orlando to 40 miles into S/c before i filled up. I drove no less the 70 Mph the whole way too.sunil6784 said:Thats impressive.
Did you figure your mileage out by diving by the number of gallons?
jtfairlane said:Uuhhh..though that rating is for the factory tires that came on the car. How many of us are running factory tires 15 years later, etc? If the factory rating, for example, is 35psi, and the tires you just bought from Les Schwab or whoever is rated of having a max of 44 psi, do you really want to stick with the manufacturer rating? No, the tires would be underinflated.
klapdout said:no, your overinflating them, that rating is the max pressure for that tire, how does that translate into what you should use??? it doesent
how did (example) bridgestone know every single (example) Expedia S-01 sold would go to a mustang with your vehicle weight/suspension so they could brand them all with the correct tire pressure for you?
use your factory rated tire pressure. adjust as nessicary based on tire wear
here, senmce i know you wont believe my word, here are a few links i grabbed in a fast seach
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=147¤tpage=33
http://www.tc.gc.ca/roadsafety/tp/tp2823/systems.htm
http://www.sportcompactcarweb.com/tech/0208scc_tire_pressure_guide/
http://cars.cartalk.com/content/advice/tirepressure.html
Black1987Stang said:I dont like that way cuz its not 100% accurate unless u completely use every drop in the tank and no ones gonna be running that low on purpose...I like Filling the tank to the top, driving ur distance noting how many miles it was and then fill up the tank up to the top again and noting how many gallons it took to fill it back up...then with that figure u can figure out how far u can go on a 10 gal, 15 gal or w/e fuel tank...Much easier and safer way imo![]()
