  • SN95 4.6L Mustang Tech
Gas pedal sticks
  • Thread starter Thread starter SmallTownStang
  • Start date Start date Sep 20, 2007
SmallTownStang
28
  • Sep 20, 2007
I don't know if it has anything to do with my BBK Throttle Body, but my gas pedal sticks right when you push down. If you push it past the stick then it is fine until you completly let off the gas. Any ideas of where to check? I revved the throttle from the engine bay with the throttle body and didn't feel anything.
Preston
lvmustanggt
721
Las Vegas
Sep 20, 2007
  • Sep 20, 2007
I got same thing with my bbk 75mm.
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 20, 2007
  • Sep 20, 2007
Rule out the throttle body and find out, remove it and drive around to see if it sticks
A
avexhype
14
  • Sep 21, 2007
DAMN same here, came with the stang when i bought it in july and i thought it was normal till i test drove a stock 02 at the dealer and noticed it was very easy to play with the gas peddle.
OV10stang
48
Pembroke, NH
Sep 21, 2007
  • Sep 21, 2007
Did your BBK throttle body come with instructions? Adjust the allen screw on the throttle body a little at a time and try it after each time. You have to test it with the engine running so it's pulling a vacuum on the throttle blade....you wont feel it stick when the car is not running. You don't want to go too far with this adjustment because it'll make your rpms hang a little before they drop to idle. This is the only reason why the adjustment screw is on the throttle body....it's not an idle screw, and will not change your idle rpm (unless you crank it all the way in). Lol, good one Tomustang!
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Engine 86 GT heavy throttle pedal
  • 86 Convert
  • Sep 4, 2025
Fox 5.0 Mustang Tech Sep 4, 2025
86 Convert
