gas smell after cold start
lilblueskeeter
22
i have a strong gas smell coming from somewhere after i start my car, when the motor is cold. I can drive it a while and get the motor warm and start it and i cant even smell a hint of gas. it only seems to be after its sat for a few hours and cooled off. It also seems to knocked my mileage down quite a bit too. Could this be an O-ring or gasket somewhere leaking till it gets warm amd seals off?
1989 5.0, K&N filter, mac short tube headers, upr O/R X, and 40 series flowmasters
any help or suggestions greatly appreciated.
possibly.. check your oring seals on your fuel injectors/fuel rail.. see if you notice any gas there..
I don't know how sensitive your nose is, but usually these cars smell like gas quite a bit after cold starting. Because the motor isn't hot, gas condensates onto the cylinder walls and intake ports and so the exhaust can smell a bit "rich". Because of this and other factors at cold start, the EEC feeds a rich mixture, so its normal to smell a bit of gas at first.
Check out this web page, its gives good info about what the EEC is doing after start up:
Ford Fuel Injection Strategies
I noticed just now that you have an off-road x-pipe. This will exaggerate the smell.
Have you made any modifications under the hood as far as removing smog equipment or EGR? Do you still have the "charcoal canister"?
the EEC under a cold start runs the engine fairly rich, in the 12.5:1 AFR, which is fairly rich, also the catless midpipe and etc doesnt help at all. my car always seems to have that smell from time to time. not a raw gas smell just that sort of exhaust smell to it. doesnt bother me at all.
It just started this about a month ago. Its never smelt of gas before not even after i got rid of my cats. its not really a faint smell either, its pretty strong. It smells like a bad gas leak (Raw Gas). One day it didnt smell and the next it did, which is why I thought something might have went out or broke. and as far as i know everythings stock except for what i listed. Thanks
