Gauge pod question
  • Thread starter Thread starter Andres2882
  • Start date Start date Aug 4, 2005
A
Andres2882
316
  • Aug 4, 2005
Hey all, have the 3 gauge A-pillar pod from summit. Question is, is that meant to mount over the stock A-pillar or do I remove it? It didn't seem as sturdy as the stock one so I have it mounted over atm, problem is that it doesnt seem to fit exactly right and thus if I look at it hard enough I can see the wires underneath. Problem just an perfectionist problem, but I'd like it to look top notch. Anyone have experience with this ?
sgarlic
3,085
Aug 4, 2005
  • Aug 4, 2005
If it's a full a-pillar pod, it fits over the stock one. The instructions should tell you that. You drill a hole on each of the corners of the stock a-pillar, and stick those little plastic rivet things on to hold the pillar pod on to it. You can either run the wires along the front of the stock a-pillar but behind the pod, or do like me and drill a hole in the stock a-pillar.. I plan on replacing the stock a-pillar if I ever sell it, but that won't be for a long time.
HISSIN50
34
129
Aug 4, 2005
  • Aug 4, 2005
Apples to oranges here. I have a triple on the '94. I did not want to butcher the stock pillar so I used the pod in lieu of the stocker. I affixed the pod to the metal behind the pillar. I used a tiny sheetmetal screw in the top inside of the pillar (so you need your head up near the instruments to see the screw. The bottom is an interferance fit.
I dont even know what a fox hardtop pillar looks like to know if this could work. I have a dual pod over the stocker on the 88 Vert.
Good luck.
sgarlic
3,085
Aug 4, 2005
  • Aug 4, 2005
Now that I think of it JT, that's probably an option for the hardtop pillar. My stock pillar on the '88 has a screw near the top holding it on and one near the bottom as well, so I don't see why you couldn't use the entire gauge pod pillar and just affix it with those screws. Good call, I stand corrected.
HISSIN50
34
129
Aug 4, 2005
  • Aug 4, 2005
Well actually, your method is 'correct'.
One reason it takes me so long to install stuff is that I have to see how I can differ from the instructions and mess it up.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
