Hi, so I am considering ordering a mechanical water gauge... my question is about the sensors... I also have a mark 8 fan that is running constantly with the two core rad.. and the original factory temp gauge stays relatively close to the center... which is good... around 200degrees.. with the fan came a sensor that turns the fan on when the coolant hits 160 degrees... But I'm not sure where I can put the sensor... I don't want to take the sensor near the front of the water jacket out because that is the original water gauge sensor.. Is there anywhere else accessable for these sensors... I think I would like to move the original water temp sensor to the thermostat housing.. If I can find one that has a spot for a sensor... and then put a new mechanical gauge sensor where the old one was.. and where should I put the sensor for the fan?
