Gauge Temp sensor question...
AnthonyR23
661
Ontario
Hi, so I am considering ordering a mechanical water gauge... my question is about the sensors... I also have a mark 8 fan that is running constantly with the two core rad.. and the original factory temp gauge stays relatively close to the center... which is good... around 200degrees.. with the fan came a sensor that turns the fan on when the coolant hits 160 degrees... But I'm not sure where I can put the sensor... I don't want to take the sensor near the front of the water jacket out because that is the original water gauge sensor.. Is there anywhere else accessable for these sensors... I think I would like to move the original water temp sensor to the thermostat housing.. If I can find one that has a spot for a sensor... and then put a new mechanical gauge sensor where the old one was.. and where should I put the sensor for the fan?
With a stock intake, as suggested check out the plugged port on the driver's side rear of the lower intake. This port is inaccurate so put the stocker there.
As you said, you can also spend 10 bucks on a new t-stat housing from the parts store. It should have a 3/8" plug/port for a sending unit (again, if you do this, put the stocker there).
If it was my car, what I'd do:
Put the stock sender in the rear of the lower intake.
Put the fan's temp switch in the t-stat housing. If the t-stat sticks closed, the fan wont come on. But if the stat is stuck closed, the fan wont help cool much anyhow.
Put the aftermarket gauge sender in the stock location.
Good luck.
