Gauges still not bright
  • Thread starter Thread starter RIP88
  • Start date Start date Sep 16, 2010
R
RIP88
9
  • Sep 16, 2010
Hey everyone I just installed my autometer ultra light gauges with the X5 LED bulbs from superbrightled.com and after suching around on here and looking at some pics of gauges at night,there still not as bright.I have the ground going to a screw behined the kick panel and the positive inline with my tach thats going to the positive on the cigerette lighter.
HISSIN50
34
129
Sep 17, 2010
  • Sep 17, 2010
Led's can be dim in and of themselves, and gauge illumination is affected by the light dispersion angle (you have wide-angle bulbs?).
Try using another ground just to see if they brighten up. You could ohm your current ground out as well. Look for less than one Ohm of resistance.
FWIW, IIRC the cigar lighter is hot at all times. You really want to use an accessory power source to diminish the drain on the battery when the car is off.
R
RIP88
9
  • Sep 17, 2010
They are 1 High Flux LED & 4 x 3mm Radially Mounted LEDs, 220 degree beam - These bulbs are Non-Polarized heres the link WLED-x5 (194 type) Wedge Base bulbs Specifications
and pull up the WLED-x5.
HISSIN50
34
129
Sep 17, 2010
  • Sep 17, 2010
Did changing the ground location help?
If you have mechanical gauges, they can seem dimmer than electric gauges (difference in gauge faces).
R
RIP88
9
  • Sep 20, 2010
Ya I changed the ground it help out but here's the new problem I'm having.I just put a 140amp alt. In and a brand new battery,but when ever I come to a stop the volt gauge will drop and lights will dim and flicker.any idea what is causing this?
HISSIN50
34
129
Sep 20, 2010
  • Sep 20, 2010
Is the alt being underspun at idle? What actual voltage are you at while idling (don't use the stock gauge as the measuring instrument)?
R
RIP88
9
  • Sep 20, 2010
14.2 is what I'm seeing
R
RIP88
9
  • Sep 20, 2010
An the car idles around 600 I have a aftermaket tach.
HISSIN50
34
129
Sep 20, 2010
  • Sep 20, 2010
14.2 V while the lights are dimming? 14.2V is outstanding, so the issue lies elsewhere. You likely either have a voltage drop occurring downstream of the battery (or where ever you measured voltage) or a ground issue in the affected circuits.
R
RIP88
9
#10
  • Sep 20, 2010
  • #10
Ya its 14.2 with everything on and that was at the battery so I'm going to pull the grounds and clean them see if that works
Electrical 5.0 Resto Gauge Cluster Fuel Ohms
  • sav22rem22
  • Dec 31, 2023
2K
Fox 5.0 Mustang Tech Mar 6, 2024
1everett1
1968 fastback, oil pressure, fuel and alternator gauges out, did these, what next?
  • phendyr
  • Jun 3, 2022
1965 - 1973 Classic Mustangs -General/Talk- Jun 4, 2022
Mcmahst
N
1995 Mustang GT cranks no start
  • NoRecoil
  • Dec 25, 2022
  • 1994 - 1995 Specific Tech
5K
1994 - 1995 Specific Tech Dec 31, 2022
NoRecoil
N
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
14K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
9
1995 Mustang GT Crank no Start
  • 95gtV
  • Sep 1, 2023
3K
1994 - 1995 Specific Tech Dec 4, 2023
SRago
