GEAR HELP....
  • Thread starter Thread starter lxwants12's
  • Start date Start date Mar 14, 2006
lxwants12's
506
  • Mar 14, 2006
i am running a 347 currently i have 4.10's i like them expect i drive the car on highway alot...i had 3.73's before and i loved them as an all around gear...now my question here is if i go down to 3.73 or even 3.90's how much will it effect my 1/4 times? mph? im running 245 45 16 nitto 555r on street then gt turbines with 26 inch et streets...currently pulling a 1.64 60 foot..
:SNSign:
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 14, 2006
  • Mar 14, 2006
You WILL slow down. You WILL waste money. Keep the 4.10, they're perfect for your heavy vert.
I'll be doing a 4.30 gear once I finish up my suspension. Not afraid of running 2,700 rpm @ 70mph on the highway in my street car
Spend your money on a new manifold. Ditch that restrictive 5500 rpm 302 intake!
lxwants12's
506
  • Mar 14, 2006
yea mike i have been thinkin bout that for a while.....can i just bolt the upper track heat to the lower street heat? the length of the runners are the only difference right? also im gonna step up in injector im running 24#r's and im sure i should go 30...but first i have to fix the rear end...messed something up in there racing sunday...loud clumping noise and when i went into reverse it was stuck till i gave it gas then it freed up...
willys1
1,004
New Jersey
Mar 14, 2006
  • Mar 14, 2006
5spd ?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 14, 2006
  • Mar 14, 2006
You can bolt the track heat upper on. I dont think it would be the best choice but it'll be cheap to do. The track runners are 3" shorter.
I'd get that rear fixed first You sure its the rear and not a clutch issue?
lxwants12's
506
  • Mar 15, 2006
yea willys its a 5 speed..tko 600......mike, im not 100% sure cause i havent taken it apart but i had the rear in stands and all the noise is coming from the rear portion of the car....it moves and shifts into everygear theres a clumping noise and feel...when i first happened i tried to shift it into the reverse gear and i went in but wouldnt back up as if the rear was locked..then i gave it a little more gas and it freed itself up
P
powermaxx
168
melfort, sk
Mar 18, 2006
  • Mar 18, 2006
if you do lots of highway driving get a taller rear tire. maybe 2in diamiter bigger should hepl to lower your rpms when driving.
G
Drivetrain trickflow Stage 3 camshaft 347 stroker. also too much gear????
  • Gross Virgin
  • May 2, 2024
Fox 5.0 Mustang Tech May 2, 2024
Gross Virgin
G
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
  • dan50
  • Jul 18, 2026
dan50
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
