Gear Kit
  • Thread starter Thread starter SteedaGT9150
  • Start date Start date Nov 24, 2007
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Nov 24, 2007
  • Nov 24, 2007
looking at this gear kit from 50 resto for xmas, while im at it what else do i need?
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-4209FRB-K%20%201&comp=LRS
P
PJB
131
Rotterdam, NY
Nov 24, 2007
  • Nov 24, 2007
You might want to pick up another bottle of gear lube. If I remember right the rear normally takes 2.5 bottles.
Otherwise everything else is there.
Thats a great deal too. I wish I had seen that when I was getting gears.
I paid $170 just for the gear install kit and the FR gears are $200 by themselves.
bloopbloob
578
Alberta
Nov 24, 2007
  • Nov 24, 2007
rebuild your trac-lok while your in there. its not much more work if your're already doing gears. i think its just under $60 from the same place. oh and a new gear for your speedo
Aryan15
236
CA
Nov 24, 2007
  • Nov 24, 2007
I would do the axle seals also.
bloopbloob
578
Alberta
Nov 24, 2007
  • Nov 24, 2007
+1, new bearings also
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Nov 25, 2007
  • Nov 25, 2007
so i just need a Axle Bearing & Seal Kit ? what do i need for the trac lock
bloopbloob
578
Alberta
Nov 25, 2007
  • Nov 25, 2007
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=AK-1563%20%20%20%20%20%20%20%201&comp=LRS
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-4700A%20%20%20%20%20%201&comp=LRS
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Nov 25, 2007
  • Nov 25, 2007
thanks man
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Engine A/C QUESTION
  • Mindseye007
  • Jun 5, 2025
  • 2 3 4
3K
Fox 5.0 Mustang Tech Jun 22, 2026
nicholase
  • dan50
  • Jul 18, 2026
dan50
Brakes Need help ID’ing which brake lines and seals I need
  • AnthonyA1234
  • Apr 2, 2025
Fox 5.0 Mustang Tech Apr 14, 2025
limp
Engine what radiator hose kit are you are running on your foxbody?
  • Mindseye007
  • Apr 7, 2024
3K
Fox 5.0 Mustang Tech Apr 26, 2024
Carpenter78
