I have the gt-40x crate motor (other mods in sig.) with a C-4 w/ manual valve body. I currently have 3.73's but I plan on going with a lower gear. Either 4.10's or 4.30's. I'm also running 295/50/15 street tires. Since I don't have OD, I was planning on going with a taller tire: BFG 295/65/15 Drag Radials to somewhat compensate for the lower gears. I will also be upgrading to a 10" 3300-3500 stall converter. Does anyone know of a chart that gives the tire-gear final ratio? The car will be weekend driven, but will mostly be on the track.
side note: I also plan on swapping my heads for some Trick Flow TW heads & putting in a TFS Stage 1 cam, so I'll be running a Trick Flow HCI combo... I'm hoping for 300-310 at the rear wheels.
