Gears with 5 lug swap
rod87
11
I had a few quick questions. I have a 90 gt with :
3.73 gears
Front & Rear Coil-Overs:
HyperCoil Springs
Bilstein Shocks & Struts
Aluminum Steering Rack Bushing
Prothane Urethane Front lower control arm bushings
Maximum Motorsports Caster/ Camber Plates
1. Will I have to get new gears when converting to a 5 lug setup. I am getting all parts from a 95 gt.
2. If i do the swap will I have to get rid of my suspension products? And what about future additions how will the sn-95 axles alter these, will i keep buying products for fox body's or sn-95 stuff.
Thanks in advance
The 5 lug conversion will not change anything else but wheel options and better brakes. as far as gears go the axles go into the spyder gears witch as long as you get the right spline, 28 or 31 you will be fine. all stock mustang i believe came with 28, might be wrong but thats what i have read. As far as the suspension goes, if the car is lowered you should be fine as long as you get the 94-95 stuff to keep the stock track. Since you have coilovers i think you might need to get 94-95 struts not sure, might want to see what other say that have done it. Hopefully i was some help :D
