gears
  • Thread starter Thread starter steel1212
  • Start date Start date Oct 8, 2004
steel1212
1,180
Frankfort, Ky
Oct 8, 2004
  • Oct 8, 2004
Hey what gear ratios are you guys running on the street? I'm getting all my info together for my 9 inch build. This car will be mostly street and some strip for ****s and giggles.
Also what type of differential would be good for mostly street but some track use?
washMO66
1,000
Washington, MO
Oct 8, 2004
  • Oct 8, 2004
Detroit Tru trac seems to work well for me.
3.70's is my gear of choice. It would be better if I had a five speed for any highway driving.
Max Power
1,774
St Paul
Oct 8, 2004
  • Oct 8, 2004
With your tranny and cam, I would recommed 3.89s or maybe even 4.10s. I run 3.50 with no overdrive and love em. If I had overdrive I would run more....
12sec67
1,301
San Diego, Ca
Oct 8, 2004
  • Oct 8, 2004
i'm running a currie 9" trac-loc and 4.11's, cruising 70 is approx 2550 with an AOD If you don't have an overdrive i wouldn't recommend going over 3.80's.
N
nosaj122081
202
West Virginia
Oct 8, 2004
  • Oct 8, 2004
I've run 2.79's, 3.25's, and 3.89's. By FAR, the 3.89 is my favorite (with a FMX auto). I don't know what I crusied at on the highway (nor did I really care), but it wasn't THAT bad (and I had Flowmaster 40's). Seems like a good medium between neck breaking take off's and reasonable RPM's (plus in a 1/4 mile with a 26" tire I hit the finish at ~6000ish). I'm using the same 3rd member in my Cougar with a wide ratio Toploader. I have a Detroit Locker in that chunk, and would never bother with a LSD again. The Locker is absolutely great and I don't have a single complaint or regret about going with it. So, my favorite combination is a 3.89 Detroit Locker.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
