gears
  • Thread starter Thread starter 1 bad gt
  • Start date Start date Feb 22, 2009
1 bad gt
  • Feb 22, 2009
what is better 4.10s or 3.73s, for a 5 speed street stang.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Feb 22, 2009
  • Feb 22, 2009
I say 3.55's, but that's my opinion
Grn92LX
Fidanza Man!
6,819
64
129
New York
Feb 22, 2009
  • Feb 22, 2009
Which ever your combo needs is the better one. I like my 4.30's in my 5speed streeter but thats what my combo needs.
1987stangman
684
24
  • Feb 22, 2009
Yep, thats the ticket. I went with 3:55's with a stock motor and it was OK but when I added my new combo it really worked well together. Gears are great but it is better when you build your car around them. Just my O2!
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Feb 22, 2009
  • Feb 22, 2009
There will be debate on this, but I'm throwing in for 3.73s. 4.10s might be good for the dragstrip, but cruising RPMs on the highway are gonna be ugly, and 1st gear is shooooort.
T
tstang93
49
Montgomery IL
Feb 22, 2009
  • Feb 22, 2009
I like the 3.73 i had in an 85 but now i have a 4.10 and its also fun but you have to decide if your goin to go on the highway. With my 4,10 its at 2000 rpm at about 45mph in 5th and im shiftin fast im only in a gear for a few seconds just crusin around
flyby84
48
Arkansas
Feb 22, 2009
  • Feb 22, 2009
I prefer 3:73 gears because you shift less often it seems...but for a stock or really mild application you can`t hardly beat 3:55s! Just my .02!
blackened88lx
Connecticut
Feb 23, 2009
  • Feb 23, 2009
It really depends on your combo and how you use your car like Grn92 said. Most people could have fun on the street with 3.55s or 3.73s just messin around with street tires. My car has 3.55s and with drag radials and they're wayyy too tall. It would really like some 4.10s.
bubba-dough
1,044
Indiana
Feb 23, 2009
  • Feb 23, 2009
Yep its all about your combo when it comes to racing and how you plan on driving the car. Imo though 3.73 is the better all around choice for fun and performance on a stock or mild bolt on.
tim281
125
Portland, OR
Feb 23, 2009
#10
  • Feb 23, 2009
  • #10
I am struggling with the same question. I had 3.73s on my 96 Cobra and they worked out really well, but that was a DOHC motor and probably not as torquey at the low end. The 96 came stock with 3.27 gears and the jump in gearing was roughly 0.5....it made a big difference.
Since the Notch has a 3.08, I am leaning toward the 3.55s (roughly a 0.5 difference also). The Notch is a lot lighter so the 3.55 change should be pretty noticable. I wouldn't go higher than the 3.73, but I can't speak from experience with higher gearing. I am looking for a gear that will be fun for the street. My main goal is to build the notch into a fun to drive car with plenty of usable torque at the low end.
parrish5o
Dirty South
Feb 23, 2009
#11
  • Feb 23, 2009
  • #11
Yeah, it depends on your combo. I like 3.73s myself. The 4.10s are pretty low for the street but tolerable.
A
anotherstangfan
38
#12
  • Feb 24, 2009
  • #12
i liked the 355's a little better than my 373's because of the slightly less amount of shifting but for a street stang i say either 355 or 373 for a 5speed
M
mercurycapri
211
washington
Feb 24, 2009
#13
  • Feb 24, 2009
  • #13
So 3.73 are better for street with a mild motor?
Bandit4142
#14
  • Feb 24, 2009
  • #14
I don't want to hi-jack this thread, but my question is virtually the same. I'm trying to decide between 3.55's and the stock 3.27's?? Here's the thing, my Mustang is going to be a daily driver, mild mod, bolt-on car. The problem is, I live in rural Colorado. If I want to go to friggin' Arby's, I have to drive 200 miles round trip.
What RPM can I expect with the 3.55's at 75mph? I'm not as worried about mpg (not that it isn't a concern), as I am the increased RPM resulting in increased heat/wear on longer trips... In the past, I've actually increased MPG, but lowering my gearing (raising it numerically) due to the fact it was running in a better RPM range in terms of effeciency. Obviously its not always the best to run at lower RPM's simply for the sake of running lower RPM.
A
anotherstangfan
38
#15
  • Feb 25, 2009
  • #15
355's would put you 2500-2800 or so at 75. i remember i was at 2000 at 65 in my fox. the 373 only put a few hundred more at any given speed.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
T
Drivetrain Can’t identify correct speedometer gear
  • townethug
  • Jul 12, 2025
Fox 5.0 Mustang Tech Jul 21, 2025
FastDriver
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
Bad a$$ '86
  • nicholase
  • Oct 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2026
nicholase
