General Maintenace Intervals?
93gtmustang
515
43
49
How often should the below items be changed?
And, if the car is used for drag racing, should they be changed more often?
Plugs
Cap and Rotor
Cleaning K&N Filter
Transmission Fluid
Rear End Fuid
Fuel Filter
Also, when running advanced timing, should you run a plug that is one step colder than stock?
I spelt Maintenance Wrong!
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 3.73 Gears / Eaton H.D. Posi / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / B&M Short Throw Shifter / BMR Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump /
