I have a 24x19 inch Griffin universal radiator with 1 inch tubes. It works great at highway speeds but runs hot when I am driving at low speeds. Also, the top right inlet interferes with the location of my alternator after my March Serp. Conversion and the bottom left outlet meant that I had to relocate my timing pointer to where I can no longer see it.
I have a transcooler mounted in front of the radiator. I have decided to get a an identically sized radiator but with larger tubes (1.25 inch, rated up to 600 hp. Or for an extra $150, I can get 1.5 inch tubes that will drop my temps even lower). I will also change the inlet and outlet locations to fix the interference with the alternator and also so I can move my timing pointer to where I can actually see it.
Now here is the thing. I can opt for a transcooler built into the radiator or keep the externally mounted unit in front of the radiator. The common consensus is that the trans cooler does indeed block "some" air flow to the radiator. My primary goal is to protect the several thousands of dollars I have invested in the engine, a .040 over, 10.5 CR 351W putting out 425-450 hp. My secondary goal is to keep the tranny cool enough.
I have just installed a B&M Racing aluminum transmission pan that holds an extra 2 quarts of transmisison fluid. My torque converter stalls between 2800 and 3000.
Which way is the best way to go; new radiator with trans cooler built in or new radiator and reuse the trans cooler I already have? Is there an advantage/disadvantage between one or the other?
