Getting code 95, anyone had this?
Actron scanner, engine skipping a little, most noticable in high gear under load at low RPM's, runs fine everyday until I shut it off when I start it up agian it skips and noticable loss of power, tried wires,plugs,cap&rotor,cpu from buddies car, gonna try his ingnigion module next?Seems somthing is getting hot and causing this? It doesn't matter if I start it right back up or let it sit for a few hours, it has to sit overnight to run good, the next day-same thing!!
Motor is 306 AFR165's typhoon intake 65mmTB longtubes TFS #1 cam 24 lb injectors 42# fuel press. 15* timing
code 95: Fuel pump secondary circuit fault
Thanks
Wes
Thanks
Wes
