getting hot
  • Thread starter Thread starter erythnul
  • Start date Start date Nov 10, 2005
E
erythnul
11
  • Nov 10, 2005
i have a 67' stang with a 93 gt engine... the car gets hott with in 15 min of driving it shoots to 250+ .. we echanged the electric fan with a engine fan and its still getting hot. we're thinking it might be the thermostate ...could there be any other reasons for it getting hot.
vristang
4,933
101
124
Seattle
Nov 10, 2005
  • Nov 10, 2005
If you describe the the temp fluctuations better, it will make it easier to help. For example does it run steady at a lower temp for a while and then jump, or does it just shoot up. Does it only run hot in traffic, or at highway speeds.
The engine fan probably isn't helping, unless there was a problem with the e- fan.
Is this a new combination? What size is the radiator, application? What t stat are you using? Water pump?
Stuff like that.
Good luck
Hope we can help.
BlackGT89
774
Huntsville, AL
Nov 10, 2005
  • Nov 10, 2005
Check and make sure the thermostat is installed properly, with the spring part pointing back towards the intake manifold.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Nov 10, 2005
  • Nov 10, 2005
Is there coolant in the radiator? What is the water / coolant ratio?
Blown head gaskets do cause overheating issues also. need more descriptive information to help
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
R
Engine Fox body doesn’t run hot until I start driving
  • Rose5oh
  • Mar 17, 2025
Fox 5.0 Mustang Tech Jun 7, 2025
limp
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
