I found a new set of PI cams on ebay for cheap, and got'em. They are romeo cams and the cam gear should bolt on.
Now, for the questions. I've done cams on my 2.3 plenty of times, but never on a 4.6. First, what else do I need to install them in my 97? Does my 97 uses a bolt on gear and have the correct bolt for the PI cams?
Also, what else can I expect to replace while I have the front cover off (if I have to take it off)? The chain guides typically wear? Gaskets? What about the timing chain? Money is quite tight, so I don't want to replace parts for fun, especially the chains if they can keep going. The car does have 167k miles and I've heard there are some parts in the front that typically wear. It doesn't make any unusual noises though.
Also, I don't really want to buy the tool from anderson to hold the cam gear. Can the cam gear be held by hand if I have a helper, or does the tensioner apply too much pressure?
Maybe that's why I like the 2.3. I can get the cam out in 15min or less and if the timing belt breaks, I put another belt on and drive away.
