  • SN95 4.6L Mustang Tech
getting tuned
  • Thread starter Thread starter tim_one82
  • Start date Start date Nov 7, 2006
T
tim_one82
9
  • Nov 7, 2006
Hey guys i have a diablosport predator and i was wondering if i should get a custom tune. So far the stangs engine mods are upper intake plenum, 75mm tb, pulleys, shorty headers, off-road h pipe, magnaflow side exhaust, clutch, flywheel, and 4:10's. I was also wondering what you guys thought of mail order tunes or if i should go to a shop or diablo dealership. I just want someone that you guys trust, and have had a good experience with. I live in western maryland and would drive a while to get this done right so if anyone has an advice id really appreciate it.
'03GTinFLA
486
St. Petersburg, FL
Nov 7, 2006
  • Nov 7, 2006
I have K&N FIPK, Accufab TB/Plenum, LT's, O/R prochamber, Mac Cat-back, Pulleys and the Predator. I put the timing all the way up and the car ran good. Then I got a tune from a very reputable shop. I'm sure they gave me a safe and the best tune for my car with my mods BUT my SOTP said I had a stronger car before the tune. Problem was they never did a baseline dyno with my timing maxed to see what it ran so I could compare. So all I have is SOTP and that tells me it was stronger before tune, but was it safe, too lean? Don't know. The tune I have now is safe.
I would say max the timing, if you have good gas in your area, and be happpy with that. If you get some serious upgrades like blower, cams, heads then go to the dyno for a custom tune.
Crzyhrse
Seattle, WA
Nov 7, 2006
  • Nov 7, 2006
Do it the right way and go to a shop and let them work off the Predator tune you already have in it. If I would have just maxed timing on my Mach, I would have been losing horsepower and torque big time.
'03GTinFLA
486
St. Petersburg, FL
Nov 8, 2006
  • Nov 8, 2006
Why would you have lost hp and torque?
There was an article running around here about maxing out the timing on a predator and the gains involved. I think Propellerhead had it. He's knows alot about the predator stuff.
I gained more hp and torque, by SOTP and spin factor in 2nd and 3rd gear by maxing timing.
It probably is best to dyno tune, but I would save my money until I had more mods, but that's just my personal experience with predator tune and a dyno tune.
No flame intended crazyhrse, just asking why.
04GTMustang
348
Stafford
Nov 8, 2006
  • Nov 8, 2006
[QUOTE='03GTinFLA]Why would you have lost hp and torque?
No flame intended crazyhrse, just asking why. [/QUOTE]
most people with mach 1s actually gain hp from retarding timing with the predator. The gts are what you want to max the timing out to gain hp.
Crzyhrse
Seattle, WA
Nov 8, 2006
  • Nov 8, 2006
This was true in my case. When the tuner guy added timing, HP and TQ dropped off. When he retarded it, I kept gaining more and more HP and TQ. I have no experiemce with the newer GT's. I had two Fox body GT's before my Mach.
SamMan
121
Denton, TX
Nov 8, 2006
  • Nov 8, 2006
Judging by the SOTP meter I mosdef had gains from maxing the timing on my GT.
propellerhead
1,541
"but what's with the but shots?"
Nov 8, 2006
  • Nov 8, 2006
Unless I had a power adder, I'd just go with maxing out the timing. Back it off a bit if it pings at WOT. I got a custom tune because I have an automatic and wanted a better part throttle shift schedule. I can't say there was a significant power increase with the custom tune.
jstreet0204
939
Winston Salem, NC
Nov 8, 2006
  • Nov 8, 2006
More timing does not always make more power even if it isn't pinging. Every car is different as to the maximum amount you can get away with before power starts to go back down. The only way to see that is on a dyno.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Custom tune?
  • Nostang25
  • Jul 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 17, 2025
FastDriver
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
H
Holley Carb Tuning Help
  • hassler
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 29, 2025
85GTStangGuy
