Gf's car ( no mustang but need ur help )
00GTpony
162
Need ur help guys....... my girlfriend has a 99 mazda 626, its been throwin a cylinder 1 misfire code.. The car studders bad on take off, or on a load... Also shakes wen sitting. I changed the plugs, wires, fuel filter, and coil... What else could it be.. Im going crazy. Please help . thanks
Check the plugs to see if one is off-color. A bad injector could easily do this and I just helped a friend fix this exact same problem on a I-4 honda accord. #4 was misfiring, and on inspection was completely black. Injector was sticking open / not closing properly.
Easy enough to fix, buy one injector and a complete set of injector O-rings as it is too easy to nick one and get a leak when removing the fuel rail.
ya im going to throw a new injector in today and see what happens. its gotta be the injector thats the only thing left.
There are other possibilities that are pretty rare. Worked on one where two of the injector wires had cracked and were shorting together. So both injectors were firing twice making for a rich condition. I was suspicious in that it is pretty unlikely to see more than one fail at the same time unless one runs without a fuel pump and fills up in the backwoods somewhere.
I changed the injector today with a new one, and its still misfires bad..... studders rele bad and stalls.. wen it studders on take off, there is also a knocking sound comming from the motor.. Im going crazy
ok, so there were brand new motorcraft plugs in there that autozone recommended, and someone on another forum told me the cars only like NGk plugs, so i put them in and the car runs great, i dont get it.
I know Ford and Mazda have ties but ... WTF? Motorcraft plugs in a Mazda? Someone at Autozone doesn't know how to read their friggin' parts screen. :nonono:
Having worked there, myself, I know that it'll list just about ALL brands for ANY make, as long as there's something listed that will cross-reference to it. Therein lies the problem. Cross-referenced plugs are not always a direct fit or replacement. The Motorcraft plugs you had in there might have been a totally different heat range that placed the electrode so far back into the plug hole that it wasn't deep enough into the combustion chamber to actually get a consistent and/or effective ignition. Why it would only do it on one plug is kinda weird, but still ... if you replaced them with NGK's or Denso plugs and THEN it worked, I'd say that was likely the case.
Import cars need import plugs, and domestic cars (generally) should have domestic-brand plugs - not because of performance differences and such, but because most Asian imports use Denso or NGK plugs from the factory. Likewise, most GM cars use AC Delco plugs, most Fords use Motorcraft, and MOPAR uses ... uhhh ... whatever they have laying around, I guess. :D But in trying to cross-reference an import plug to a domestic, they just try a "well, that's the closest fit we make" kind of approach, and that can yield some crappy results.
Glad you got the car workin' good, though. Are you taking the injector back? I would - it was the 'Zone's fault for having crappy cross-referenced plug numbers in their system in the first place (and a dummy working behind the counter that thought Motorcraft is OEM for Mazdas).
