Grady, for the first time ever, since I've basically avoided the tuning forums in the way of trying to offer any advice, I have no idea what you just said to me.
I need to do some more reading.
Matt
I'm shocked
and
Deeply hurt
I thought everybody reads every post I put up
especially
In the tuning forum
Allow me to elaborate
The offsets we talked about are a function named .......
Injector Offset vs Battery Voltage
The breakpoint is a scalar named ......
fuel_injector_breakpoint
Injector tuning is accomplished V E R Y differently in these two pcm's
You see the slope values being equal in the j4j1 which some have
said makes the breakpoint null and void
You see the offset values being about 200% greater on the t4m0
We need to bring up these things due to you using inj's other than
the default 24's you find in the j4j1
IMHO ... if you are gonna do unequal slope values with the 19's ...
You're gonna have to then deal with a breakpoint
and
You should start your injector tuning with the 19lb inj offset value
btw ... DO NOT try to take info to heart about injector tuning from
any Fox threads you might find on the forums as they are totally in a
different dimension than our pcm :Word:
Actually Matt ... I'd focus on CBAZA threads only about ALL parameters
in the pcm so you don't get misled by info that does not work
with your 94-95 pcm
We have talked about this subject over the years here so you should
be able to find some info and details on injector tuning in the tuning
or tech forms.
Some of that stuff goes way back
before they even started the tuning forum
and for that stuff
You'll find it of course ... in the Tech Forum
Hope this makes it more easy for you to relate
and
find all the details
Grady
