bluevenom867 said:Gopher what converter are you runing?
Yah no problem If i didn't already have so much money tyed up in my 351w i would have started a big block swap now aswell.The Fox said:Im the current high bidder now. $350 would be nice for headers, oil pan, motor mounts, dipstick, gaskets and header bolts.
Thanks again for the heads up.
c-4
i never ran it at the track again as i dismantled the combo to build a more serious setup which will also be backed by a c-4( or as much as i hate to say it a powerglide, simply because i like to streetrace and with my new combo the c-4 may cause it to be a little to violent off the line on the backroads!!!!!!!!!!!!)
those would be the key words right there. Behind my 557 a C4 might pick up a tenth or two. Certainly not worth it to me, the C6 is bulletproof, the C4 is far from that.auto02 said:if you build it properly
