Going nuts!
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Jan 23, 2011
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jan 23, 2011
  • Jan 23, 2011
Got the turbo done and have been driving it a bit now,did some hard pulls and it does fine..just seems like i'm getting oil from somewhere?So i bought 2 of this type of breathers Billet Specialties 21120 - Billet Specialties Valve Cover Breathers - Overview - SummitRacing.com one for each V/C.I have the PCV plugged in the back of the lower intake.I also notice the dipstick gets pushed out a little also.So does this sound like it still has to much crank case pressure?Or something else is wrong??I havent had it on the dyno so i have no clue how much power i'm making?But another guy is laying down 600+ and has the same set upwith no problems,his engine is brand new.Mine is a fresh rebuild and i would say at the most 20-30000 miles.I thought maybe the V/C were leaking so i put new factory gaskets.I see some residue by the head studs so dont know if thats a big concern or not?Just getting ideas before i go removing the turbo system so i can see down the side of the passengerside.peace
john
Boosted92LX
5,721
4,244
224
Jan 23, 2011
  • Jan 23, 2011
I had that problem with nitrous in my 357w on hard pulls. Dipstick pushing out, blowing oil. what I did was welded bungs in my headers at an angle and ran a hose to the valve covers/breathers to help evacuate cc pressure. not exactly emissions friendly but it did the trick.... haven't seen that trick for turbos.....maybe more breathers or run a hose to the down pipe...
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jan 23, 2011
  • Jan 23, 2011
The mid pipe i had on my N/A set up had that also,the guy i bought it from had it that way.I dont remember his combo except it was a 351.peace
john
rdharper02
like kicking myself in the junk
703
237
84
Jan 26, 2011
  • Jan 26, 2011
I had the same problem after installing my turbo kit. I am still using the stock valve covers and utilized a breather in the place of the oil cap. Its basically venting the extra pressure into the atmosphere, but stopped the constant ejecting of the pcv valve (and oil leak) from the back of my intake. I am still working on the method I will use for the next motor, but am thinking either a dual breather setup or a catch can style recirculation.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Jan 26, 2011
  • Jan 26, 2011
sounds like to much CC pressure still... id go with open breather filters.
87coupe50
105
WAYNESBORO, PA
Jan 26, 2011
  • Jan 26, 2011
most likely that small nipple on the breather is not enough to reduce crankcase pressure. You can try using what you have with an open breather where the PVC is OR you need open breathers on the VC's OR a VC breather like you have but a 5/8 - 3/4 outlet nipple going to a catchcan with an open breather on top. (or an evac system like previously mentioned)
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Resolved Coolant blowing out of valve cover??
  • sav22rem22
  • Nov 1, 2023
5K
Fox 5.0 Mustang Tech Nov 19, 2023
sav22rem22
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
14K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
Betty white budget build
  • Stevenmverrill
  • Jun 16, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2023
2Blue2
