Going to flat top pistons?
1973mach1
457
PA
IM going to be pulling my 351c 2v soon, its a 72' engine I was wondering if adding flat top pistons 9.1 to 1 compression would make much difference over the dished pistons they used in 72' and 73', 8.6 to 1 compression I think they had? How much compression do I want for an street engine like this?
Thanks,
Jim
that depends on some stuff: the octane of your local premium, how big a cam you have (since a big one can sometimes effectively lower your static compression)...off the top of my head i'd say 10:1
If you have the 2v heads the flat top pistons (+2 to 4cc’s) should net you just around 10:1, and that should be fine. If you want more compression you will have to mill the heads (and intake manifold). If you have 10.5:1+ compression I’d run a minimum of 92 octane.
If you had quench heads you could run more, but I’d stick to 10.5:1 or less with those heads.
