Good Automotive Calculator
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Thought this might be of use
http://www.gtsparkplugs.com/AutomotiveCalculators.html
Has the following calculators
  • Gear and Shift
  • Tire Size
  • Carb Size
  • Wire Capacity
  • Injector Size
  • F/Iinjector pressure change
  • injector H/P
  • Speedometer gear
  • Compression ratio
  • Effecctive Compression ratio
  • Flow Unit Conversion
  • Injector Duty Cycle
  • Ohm's Law
  • Dropping Resistance
  • MPG and Fuel Cost
  • Corner Weight
  • Valve Uncut Seat Pressure
  • Wheel Bolt Circle
  • Bolt Circle Distance
  • Camber Offset
Reactions: A5literMan
