What is a good front brake set for cheap for a 95 gt, i drive alot and im basically just not satisifed with my stoping speed. my pads are in good condition, but rotors are warping, so lemme know if u have any good suggestions, Thx
That's a no brainer. Swap to 94-04 Cobra front brakes. The kit is $400, and it's a direct replacement.CArkid0101 said:What is a good front brake set for cheap for a 95 gt, i drive alot and im basically just not satisifed with my stoping speed. my pads are in good condition, but rotors are warping, so lemme know if u have any good suggestions, Thx
yup...i got that kit...took maybe 2 hours max from getting the car in the air until touch down...and they look good too.Rootus said:That's a no brainer. Swap to 94-04 Cobra front brakes. The kit is $400, and it's a direct replacement.
Ah, you've hit on something I've been wondering about. I'll be upgrading to the Cobra kit (actually, the Bullitt kit; same thing), and was wondering about the master cylinder. I hope I'm not hijacking this thread - I think it's on topic.stangla2 said:Make sure that you switch the master cylinder, your brake pedal will feel better and you will get better response
I presume the point is to get a larger bore, to increase the force applied when you push down the pedal.Be careful what you buy. The Corvette C5 uses the same PBR calipers as the Cobra. There be a reason the low-end Baer kit looks just like Cobra brakesgo-stang5.0 said:If you wanna spend a bit more...Baer has a new twin piston brake setup that uses the corvette c5 calipers instead of the PBR (cobra calipers) and they say that the initial stopping distances are better then the brembo cobra R setup. I dont remember how much it costs though.
Chythar said:Ah, you've hit on something I've been wondering about. I'll be upgrading to the Cobra kit (actually, the Bullitt kit; same thing), and was wondering about the master cylinder. I hope I'm not hijacking this thread - I think it's on topic.
What master cylinder would be better? 94-95 Cobra? 93 Cobra?I presume the point is to get a larger bore, to increase the force applied when you push down the pedal.
