- Feb 15, 2007
- 20
- 0
- 0
I have 351 block bored to a 358 with probe diamond pistons,comp solid roller cam with a 588/612 lift and 288/300 duration,track heat twisted wedge heads stage 2,victor jr intake,850 holley and 1.7 trickflow rockers. The engine has 11.1 compression. It also has a 150 shot. Fuel cell,nitrous tank and battery located in back with 2 complete fuel systems. TKO 600 and all the supporting mods. It has moser 31 spine axles with C clip elemnitor,moser spool,3:73 gears, Mac rear end girdle,Axle tubes welded,subframe conn.double adjusable lowers,Metco lowers,airbas with drag springs and 90/10 lakewood shocks. It has all MSD ignition, aluminium rad. 2 electric fans and several other supporting mods. Everything has about 1000 miles. Was wondering if anyone else is running something similar or just opinions of horsepower and 1/4 track times. I have not had it dynoed or took it to the track yet. Also has full int. No ac or heater. Any opinions will be appreciated. The motor was built not long ago, it is a 72 block
Thanks
Keith
Thanks
Keith
