- Jul 2, 2005
- 9
- 0
- 0
ok i have a 91 gt mustang. it is all stock except for the flowmaster cat back what are some good first mods? i want around 350 hp. but i dont have a super amount of money.
Nothing better than buckets of bad advice..A/C when off is no more than a low restriction pulley, removing it will be of no benefit unless your after significant weight reduction and ALL aspects of excess weight are to be removed..A/C system is best left in place. Cold air intakes offer zero benefit over the stock system less the silencer and a cotton panel filter..the stock box and cotton filter offer PLENTY of air for most any HCI 302/306 N/A set up and infact IS a cold air intake in it's design. Good advice is to look for is bump the timing, subframe connectors, gear ratio swap, aftermarket shifer, underdrive pullies, exhaust mods...etc...look at SROTHFUSS's list-very good approach.bdollarbill said:Go for cheap HP gains lose the long stock belt & bypass smog & AC compressor with short belt around $30 will give you a couple HP's. Also a cold air intake is a big performance gain not real big HP gain though. Everyone else can pipe in the high dollar stuff, like intake,exhaust, cam etc...
304billet said:The only way to achieve 350fwhp NA is to swap out the heads, cam and intake. AFR165, TFS TW heads, RPM ll intake port matched, Comp Cam XE274HR, Accufab 65mm TB, PMAS 70mm, MAF, LT headers. Costs about $4K w/ labor.
u could also just thow a S-trim blower on it 10-12lbs of boost and hit 350rwhp. $4K.
If I had this choice I would do the blower.
IntenseBlue said:Oh, another good starting mod would be underdrive pulleys.
:SNSign: Not sure about the last statement though.304billet said:The only way to achieve 350fwhp NA is to swap out the heads, cam and intake. AFR165, TFS TW heads, RPM ll intake port matched, Comp Cam XE274HR, Accufab 65mm TB, PMAS 70mm, MAF, LT headers. Costs about $4K w/ labor.
srothfuss said:Your first mods should be as follows (my take):
In order of Priority
1) Subframe connectors (SFC's) full length ones are prefered
2) Gears: 3.73:1 or 4.10:1 seem to be the popular choices
3) Buy a K&N panel filter (no CAI kit required) and put it in the stock box
4) Exhuast (headers, hi-flo cats, mufflers)
5) 3G alt upgrade / electric fan
6) Larger MAF, TB (your car will be speed density so skip the MAF part of this)
7) Fix the weak brakes
8) Bumped timing (free mod) 10 Degrees is stock.
After those, it's pretty much up to you. There are plenty of Super Chargers or Heads, Cam and Intake packages to choose from.
Also, don't forget about the basic tune up which should include:
1) Changing all of the fluids (oil, coolant, trans, rear end, brake and some of the power steering)
2) Plugs: (non-platnum type) Autolite or Motorcraft
3) Oil filter: Motorcraft or equivalent (not FRAM)
4) Air filter: see above
5) Plug wires: Ford Motorsport (FRPP) 9mm units are great
6) Cap / Rotor
7) Oxygen sensors
i only read a few postsbdollarbill said:Go for cheap HP gains lose the long stock belt & bypass smog & AC compressor with short belt around $30 will give you a couple HP's. Also a cold air intake is a big performance gainnot real big HP gain though. Everyone else can pipe in the high dollar stuff, like intake,exhaust, cam etc...
can be had for $300-500 GEARS only way to go
