Good motor build budget?
ga94gt
138
Ringgold GA
I am thinking of building a 306 and was wondering what a good budget would be to build a 300 rwhp 306. I was thinking some Twisted Wedge heads, stage 1 cam and 1.6 rr's. Not sure about pistons, rods etc. Suggestions welcome.
I went over the cost of getting my block machined, crank turned, new pistons, new I beam rods, all ARP hardware, and bearings/rings. The time to assemble it, drive time picking up the parts and taking them into get the work done.
vs.
ordering a DSS/CHP shorblock assembled.
After looking/pricing things it is a good deal to get a DSS/CHP assem. shortblock.
My shortblock shipped to my door was around $2,19x. I am 100% happy with it so far as well.
so with $2,000 for a shortblock and a TFS/AFR combo would be around $4,500 area. I would even contact FTI or camshaft innovations to see if they have any "packages" if you want the most out of that stuff...it will cost more but if you want 0 questions as to if its going to hit your goals GO to them.
vs.
do you have any idea what your set up is putting to the tires?
2 weeks ago our local site had a portable dyno at a show. 99* and 43% humidity (by the printout but that area was in the shade and had a fan blowing on it) and 100* and mid 50's humidity I later found out by a weather station.
251rwhp and 286rwtq...with little to no WOT tuning done yet. At most it has 30* total timing right now. A few people made passes later when the humidity dropped abit (IIRC 20% or so) and picked up 9hp. That was also with the stock 4 cat H-pipe on instead of the o/r H and stock t-body.
For the conditions and little WOT work I was happy. My goal is around 275-290 to the rear wheels in the end. I should be able to get in that ballpark now that I finaly have a W/B to tune my WOT. I only pan to add a 70mm t-body at some point.
I have a 150hp n2o shot on as well...so with 275 off the bottle and say and added 125 from the 150 shot and that will be a good power outcome when needed.
I got the pro-bullit 306 shortblock that came with the "level 10" block. I really dont buy into the whole "stronger" deal but I do like the fact its CNC'd.
I want to say shipping was somewere in the ball park of 175...but the total I gave is the total to my door shipped.
I live in St. Louis and DSS is around Chicago so it was really close...so if your say in florida it may be more.
my initial budget was 6k for my CHP 331 with AFR 185's...that turned into 9-10k very quick!!! i stopped adding up evreything after about 7k LOL but it's a passion so i dont complain. It's all worth it when you fire it up.
Well I am only 19 so I am trying to keep the cost low. I figured to spend about $3500 would get me where i wanted to be.
I dont plan on going over the top but i have been looking at a PMS to go with it so I can tune my own car instrad of paying someone to do it.
Do yall think with (306) TW heads, stage 1 cam, 1.6 rr's, ported cobra upper and lower, 24lb injectors and LMAF get me to 300 rwhp through an auto.
you will be close but not quite there i think...steve at powertrain dynamics is expecting 330-350 RWHP from my 331 with AFR 185's, TFS stage 2 cam, full exhaust with longtubes, Track heat manifold, and all the bolt-ons.
Whatever you plan on spending, add at least $1000 to it and that's about how much you'll end up spending. :)
Why not use your stock bottom end? You could easily get to 300rwhp with your $3500 budget if you kept the stock shortblock....
The motor has 180,000 miles on it that is why I am going to get the new motor.
Gotcha. That's the same thing I did, except mine was at 167k when I pulled the motor.
http://dssracing.com/newbullet.htm
Short blocks starting at $1600. I would spend a lot of time on ebay if you plan on staying with that $3500 budget. If you buy everything brand new expect to go over budget very quickly.
I planned on $5-6k for my engine. :rlaugh: I haven't added everything up, but I know it's between $7-9k. I replaced pretty much everything tho.
:D What's wrong with that???? You have a gr8 motor, just put on a used $1200 blower kit or turbo and be done with it. It will take awhile to crack it and the worst that will happen first is a blown hg. It took me a long time and severval different power adders on my stocker until I finally melted a hyper piston. IMO too many folks are scared to just run a stocker. It's not gonna blow up and in a million pieces, it'll just shut off or run like crap. In that case just drop in another stocker for $200. :shrug:
http://forums.stangnet.com/showthread.php?t=716288
