These BBK 1 5/8" shorties are getting installed on Friday. Will I be able to hear, or feel any difference after they're on?
Are you talking to me? I don't have a stock H, and I don't have cats. My stock headers are definitely the weakest link in my exhaust system.90mustangGT said:Going to a larger tube header on stock H and catback would not be a good idea because you will loose velosity into the H pipe, so not as much energy there to push the gasses through all those cats. However, going with 1 1/2 mandrel bent header will keep the tube diameter the same, keeping velosity but without the kinks that cause backpressure and uneven flow. I hope I am making sence here.
I think since you have stock H pipe and all, which is a larger restriction than your headers by far, maby you should replace that with a higher flowing midpipe or go all out and get some longtubes with o/r midpipe.
The prochamber sounds real good with stock headers or shorties, maby you should look into it....
